Ignition Switch
Old May 14, 2003 | 08:38 PM
Dan76'F100's Avatar
Dan76'F100
Question Ignition Switch
What should be hot with the acc. position Vs. the run position?
Radio, wipers, gauges, cigar lighter, coil, voltage regulator, ignition module, ect...And does everything cut off in the start position?
Old May 14, 2003 | 10:14 PM
Mil1ion's Avatar
Mil1ion
Ignition Switch
Power in Accessory position / In RUN position
Radio = YES / YES
wipers = NO / YES
gauges = ? ? YES
cigar lighter = YES / YES (always powered)
coil = NO / YES
voltage regulator = NO / YES
ignition module = NO / YES
Heater = NO / YES
NO, But you will notice a loss of power (spike) when key moved to start, due to the starter needing so much power
__________________
Old May 15, 2003 | 12:33 AM
Dan76'F100's Avatar
Dan76'F100
Ignition Switch
So, it's just the radio that works in acc
I have the wipers, heater, radio, gauges, I don't know about the voltage regulator or ignition module
Where is the voltage regulator at?
Do I have something crossed some where? I fixed my parking lights on with the key prolbem by disconnecting the big green dash light wire from the radio wire.....
Old May 15, 2003 | 01:07 AM
Mil1ion's Avatar
Mil1ion
Ignition Switch
Do you have a picture of that BIG green wire?
Does it have some yellow on it ?
Ford used a Green/yellow wire run across the under the dash for courtesy lights.
This would run the glove box light & underdash courtesy lights.
Here is ignition switch trouble-shooting chart.
Old May 15, 2003 | 12:48 PM
Dan76'F100's Avatar
Dan76'F100
Ignition Switch
Thanks for the help and wiring diagram.....
What does the following run?
Acc 1 = ?
Acc 2 = ?
Ign 1 = ?
Ign 2 = ?
P 1 = ?
P 2 = ?
St = Starter and ignition module?
And why is there 2 "Bat" terminals?
Old May 15, 2003 | 02:50 PM
Mil1ion's Avatar
Mil1ion
Ignition Switch
You're going to have the FORD guy who designed the circuit to find out.
This info is not readlily available.
Old May 15, 2003 | 09:55 PM
Dan76'F100's Avatar
Dan76'F100
Ignition Switch
Should I have a glove box light, or underdash lights?
The only light I have is a dome light...Controlled by the headlight switch and the door pins....
I have a ranger, not an xlt, but if it never came with one the wire should be there, right?
Is it plugged in with the all black dome light wire? (in the same harness? - Black plug by the headlight switch)
Where is the underdash lights located?
Does the glovebox light have it's own switch?
Old May 15, 2003 | 10:12 PM
Mil1ion's Avatar
Mil1ion
Ignition Switch
I'd still like to see this green wire.
If you have the Light package you would know it as it is an option.
You don;t have it.
Yes the glovebox light has a built-in switch to it.
mu2bdriver
Jan 16, 2014 10:34 AM
gangstakr
Jun 10, 2007 04:22 PM
skeleton
Oct 4, 2002 07:42 PM
Ken2600
Aug 14, 2002 02:24 PM
