Fuel Filter switch?
Old Jan 6, 2020 | 05:00 AM
siamoutas's Avatar
siamoutas
Fuel Filter switch?
Hello all
I have a 1995 F350 7.3 with a nasty fuel leak I found on a component screwed on to the lower rear fuel filter housing.
Looks like an oil pressure switch with a single terminal. Looking at Mitchell on demands wiring diagram and according to wiring color (red/white stipe) its called a fuel filter switch.
I am assuming when pressure builds up from a restricted filter switch closes and lights up an indicator in dash?
Planning on not replacing but rather pluging it with a 1/8 plug. Any knowledge to help me confirm what this component is and what might happen if I dont conect.
Old Jan 6, 2020 | 08:27 AM
farmert's Avatar
farmert
You are correct on the switch name, but it senses a restriction in the fuel flow, be it from a clogged filter or a plugged fuel line. It is not really needed, and if you use the pipe plug, do not over tighten it as you can split the port that it screws into, and a new fuel regulator is the only fix.
Old Jan 21, 2020 | 09:53 AM
Airstreamer67's Avatar
Airstreamer67
That light can help when it senses an obstruction in the fuel system before the problem leaves you on the road and in need of a tow.
Except for that, it is not needed, similar to other warning lights.
Curt Bates
13
Jan 6, 2012 08:42 AM
adrianlovessnow
Jan 9, 2008 04:35 PM
powerstrokefreak
Jan 10, 2005 08:36 AM
RICE H8R
Aug 7, 2004 12:18 AM
Drive
1983 - 2012 Ranger & B-Series
22
May 18, 2004 12:49 PM
