1986 Dome Light
Old Jan 5, 2020 | 07:47 PM
jnphillips77's Avatar
jnphillips77
1986 Dome Light
Hi! Help!
I have a dome light with a cracked plastic terminal housing which leads me to believe it is disconnected, however what is worse and a whole other problem is that when I switch the map lights on the middle dome light comes on, brighter if I switch on both. Also when those are switched on, the dome light will only work if the door is closed. Something seems reversed... any advice from the wiser among us?
josh
Old Jan 7, 2020 | 05:15 PM
Franklin2's Avatar
Franklin2
Here's a diagram. You should have a lightgreen/yellow wire up there. It should be hot all the time 12v. It's for the map lights which can be used at any time. If you can't find a lightgreen/yellow wire up there, that means someone has installed a light with the map light option that your truck was not wired for.
There should be a black/lightblue wire up there, that turns the dome on from the door switches. There should also be a black/pink up there, that turns the dome on from the lightswitch. Do you have a cargo light on back of the cab? If not, that is another clue that your truck did not have the lighting group option. You should have dome lights under the dash on each side also if you have the lighting group option.
Old Jan 7, 2020 | 08:06 PM
Kramercd's Avatar
Kramercd
Sounds like the map light grounds are running through the dome light. I'd inspect the wiring around the door jamb switch. They get monkeyed with because of the buzzer.
Old Jan 12, 2020 | 01:00 PM
jnphillips77
Continuing...
Yes, I have both a cargo lamp and floor lighting... the main light turns on when the door is closed and you flip the switches for the map lights... I have never seen the map lights come on. Could I splice into the cargo light wire or should I just look for the third wire yellow and green that I don’t see?
Old Jan 12, 2020 | 06:59 PM
Franklin2's Avatar
Franklin2
What color wires do you have at the domelight? Do you have a black/lightblue wire up there?
Old Jan 15, 2020 | 02:22 AM
BigBlue2's Avatar
BigBlue2
Check the ground screws. IIRC the screws go through the wire end fitting and are also the fixture mounting screws. If the map light has been removed before the connections could have been kluged. It's not a robust design.
Old Mar 13, 2021 | 08:35 PM
Dcurre1's Avatar
Dcurre1
Hey guys having a similar issue with my 86 Bronco. Pulled a dome light from the yard and the main bulk works with open doors as it should but neither switch work. Also there’s only one black wire up there in the photo. Is this normal and if so am I doomed to no light switch?
Old Mar 13, 2021 | 08:36 PM
Dcurre1's Avatar
Dcurre1
Don’t mean to hijack the thread but I couldn’t find any ring else on this.
Old Mar 13, 2021 | 10:02 PM
BigBlue2's Avatar
BigBlue2
Wow...kinda rusty up there. I think the black wire is the ground. Take a mirror and look around behind the liner and see if you can find the hot wire.
Old Mar 14, 2021 | 08:52 AM
Franklin2's Avatar
Franklin2
If your truck did not have the lighting group option, then you may not have the wire you need for the map light function. You can see in the diagram below near the bottom, there are two options. A plain domelight option which only has a black/lightblue wire and the map light option which has a extra lightgreen/yellow wire.
Luko
Nov 29, 2017 09:19 AM
brouse1981
Apr 28, 2016 02:21 PM
papazig4726
Mar 6, 2015 06:07 PM
ottoparts
May 11, 2014 11:44 PM
jarnold60
Mar 18, 2008 03:41 PM
