Interior lamp/Dome lamp
Old May 11, 2014 | 05:53 PM
ottoparts's Avatar
ottoparts
Ive tried searching and could not find what I was after.
We want to put in a dome lamp out of a newer truck into my sons 79. The newer style dome lamp has his/hers map lights.
Who has out one of these in and how did you wire it up?
Thanks
Old May 11, 2014 | 06:08 PM
GLR's Avatar
GLR
The Crown Vic/Grand Marquis dome lights are similar if not the same. You can use your stock wiring for the dome light. If you want to have the map lights work with the dome of you need to run a separate power wire to the switches - should be fused. At least this is what I found out when striping demo cars.
Old May 11, 2014 | 06:32 PM
fmc400's Avatar
fmc400
MSEE
As said above, you'll need to run the courtesy lamp circuit up to the dome light location. This is GREEN with YELLOW stripe, which among other things, provides power to the dome light portion of the headlight switch, and each door jamb switch. In the factory configuration, only switched power (BLACK with BLUE stripe) runs up to the dome light.
Old May 11, 2014 | 11:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
landers0440
Apr 15, 2019 09:10 AM
Luko
Nov 29, 2017 09:19 AM
BainbridgeBrewer
Dec 31, 2016 08:38 PM
papazig4726
Mar 6, 2015 06:07 PM
Greg 79 f150
Electrical Systems/Wiring
Jun 5, 2004 09:10 AM
