Remote oil filter
Old Jan 18, 2004 | 03:10 PM
jwcnj45's Avatar
jwcnj45
Remote oil filter
I tried posting this question in the lubrication board but didn't get an answer so I will try it here. I know that some of you guys must be using a remote oil filter set up. Especially with a Volare set up. Here is my question. I bought a remote oil filter set up from Summit some time ago. I mounted the adapters to the engine and found a good spot for the remote filter. I don't have the directions that came with it any more. I want to run the lines now. Each adapter is marked with "in" and "out". Do I run the lines "in" to "in" and "out"to "out" or is there another way.
Old Jan 18, 2004 | 03:15 PM
68torino's Avatar
68torino
While I have not run a setup like that it would make sense to me to run in-in and out-out.
Old Jan 18, 2004 | 03:17 PM
jwcnj45's Avatar
jwcnj45
That's what I figure but I just want to be sure. Thanks for your input.
Old Jan 18, 2004 | 03:34 PM
stockcar nut's Avatar
stockcar nut
Hey guys. don't get it backwards. Think about it, the adapter at the block "out is oil going to the filter, in is for oil coming from the filter" at the filter " in is for oil coming from the block and out is for oil going to the block". Out to in / out to in. Filters don't take kindly to oil going through them backwards. Tom
Old Jan 18, 2004 | 04:11 PM
jwcnj45's Avatar
jwcnj45
So it's out to in then? OK. Thanks.
Old Jan 18, 2004 | 04:15 PM
truckfarmer's Avatar
truckfarmer
The engine will not get oil if it is hooked up backwards. There is a check valve in the filter. Ask my son how I know this. I think we plumbed it so that the center of the adaptor went to the center of the filter mount.
Old Jan 18, 2004 | 05:00 PM
jniolon's Avatar
jniolon
old and in the way
inzies and outzies..
I think I'd embarass myself and give Summit a call... that way when it locks up you can sue them...
I've had to do it before... when you're seven years into a project... you forget how things go/went/work/are located/etc..
John (too cool to let a parts chimp embarass me !)
Old Jan 19, 2004 | 03:07 PM
jwcnj45's Avatar
jwcnj45
Took your advice John and called Summit. The correct way is out of motor to in on filter and out of filter and into motor. The tech service dept. at Summit instantly had an answer for me. I have to praise them on their service.
Old Jan 19, 2004 | 03:38 PM
joners's Avatar
joners
That is correct. I almost hooked mine up wrong too, I hate reading instructions. hehe
