Electric Choke Setup?
Old Jan 4, 2020 | 06:12 AM
66v8baby's Avatar
66v8baby
Why not just hook up the manual choke? Seems like the easy answer to me. I have the Summit Racing 600 cfm carb on my '76 390 F150. The original stove choke tube broke off in the exhaust manifold. Rather than hook up the electric choke that came with the carb, I installed a Holley manual choke kit.
Old Jan 4, 2020 | 08:48 AM
worldoftone's Avatar
worldoftone
I'm running a mid-60s Carter AFB w/electric choke on mine. I found a switched spare 12-volt tap with a plug-in lead behind the dash and have been using that for a couple of years now with no issues. My particular carb choke needs the 12-volts to operate properly.
- WOT
Old Jan 4, 2020 | 10:47 AM
Rollbar's Avatar
Rollbar
Originally Posted by Crop Duster
All your gauges work with a constant voltage regulator that only puts out 5 volts. If you hooked it up to a high current draw like a choke it would burn up the CVR in short order. Like was said in the other posts you need a separate wire with it's own fuse.
In the climate you have down there you probably don't even need a choke. One thing to keep in mind with those electric chokes, unlike a stove choke, is that they have no way of knowing your engine is warm. If you drive it somewhere and get out for 20 minutes that choke is going to go full on if you step on the accelerator pedal. You may have to adjust it until it only closes 2/3 to 3/4 closed. Just enough to get it on the high idle cam but not so much that it floods the engine.
Thanks, didn't know about the voltage. Good to know.
Was thinking about it, still might go that route. I think they are $40.00 +Shipping for a manual setup.
- WOT
Looking at the ignition switch the other day I might have seen a few wires floating that I can check and maybe tap into.
I'll take a look.
Thanks all,
JB
BeauF0RD
47
May 19, 2019 05:47 PM
gostephen
Dec 17, 2018 10:14 PM
avellaneda13
Oct 26, 2016 01:53 PM
lucky_strike
Sep 21, 2010 05:35 PM
GreatNorthWoods
Feb 2, 2003 11:44 PM
