Universal Garage Door Issue
Old Dec 31, 2019 | 08:41 PM
RyanTheSimp's Avatar
RyanTheSimp
Felt like I should share this discovery in case someone else has the same issue.
My universal garage door opener in my visor of 2016 f150 would only open my garage door on the return back to the garage. Never the departure. It was racking my brain for sometime trying to determine why would the opener only work after the truck was being drove around. It's not like the electricity to the remote was any different than at start of the day vs later.
But then it dawned on me. Maybe it was not the truck but the opener. The opener would have it's lights on during the initial use of the built in UGDO visor. But not when I was to return to the garage after a trip. The light would be off because nothing had activated it yet. What appears to be the culprit is I have an LED bulb in my opener. That bulb is interrupting the signal when on and not when it's off. Turned off the light completely and door and remote work great. Put normal bulbs in opener and opener and remote work great. Put LED bulb back in and opener and remote won't work.
​​​​​​Weirdest thing but glad I figured it out because that was a perplexing issue. Hope this helps someone.
Old Jan 1, 2020 | 12:28 AM
JKBrad's Avatar
JKBrad
Hi Ryan. And welcome to FTE!
Good point on the bulb. It would probably be an easy fix to lut a resistor in line if having an LEB bulb is important to you.
Old Jan 1, 2020 | 08:28 AM
alloro's Avatar
alloro
Often regular bulbs don't last in an opener because the vibration can break the filament. If that's happening, go get a rough service bulb as they have a heavier filament that will handle the vibration.
Old Jan 1, 2020 | 12:46 PM
Kingofwylietx's Avatar
Kingofwylietx
OP, you might try a different brand of LED bulbs.
I’ve been using LED bulbs in my garage door openers since LED bulbs came out...I’ve never had an issue with interference.
I have heard of the issue, so I know it exists, but not all bulbs cause that problem.
Old Jan 1, 2020 | 04:05 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I second Kingofwylietx . I have two LEDs on my garage door opener and know of several friends who have LEDs on theirs as well. I wonder if something is wrong with RyanTheSimp's LED bulbs or if they are a super low cost unit that doesn't meet FCC regs.
Old Jan 1, 2020 | 04:10 PM
CathedralCub
FTE Community Team
Good diagnosis though. It would have taken me quite a while to put these behaviors together.
Old Jan 1, 2020 | 05:57 PM
seville009's Avatar
seville009
Same thing happened to me maybe three years ago - put led bulbs in my garage fixtures and started having problems with the garage door opener. Switched the bulbs back to the old style and problem went away
put different newer style led bulbs in later though in the garage fixtures and haven’t had any issues with those
Old Jan 1, 2020 | 07:56 PM
Snowman 8's Avatar
Snowman 8
I also had that happen quite a few years ago with LED bulbs. I put the incandescent bulbs back in and it worked fine. I haven’t tried LED’s recently though to see if new bulbs are different.
Old Jan 2, 2020 | 08:08 AM
lg3rd's Avatar
lg3rd
Do you know the brand and type of LED lamp that was in there? There are many different design features in LED lamps and it would be interesting to identify which laps cause the problem.
Old Jan 2, 2020 | 09:40 AM
GlueGuy's Avatar
GlueGuy
Almost all LED bulbs these days have a voltage regulator to (1) control the voltage to the LEDs and/or (2) control the current to the LEDs. The circuits to do this are somewhat varied, and often involve a high frequency switching power supply. Depending on the frequency, they can interfere with the radio frequency of the remote control. It would be somewhat involved to figure out what frequency each LED uses, but I would generally guess that cheaper ones are the noisier ones.
Old Jan 2, 2020 | 12:47 PM
Going_Going_Gone's Avatar
Going_Going_Gone
This probably isn't a solution to your issue, but this story is too weird not to tell. Every light in our house is LED, even nightlights. A couple months after the original circuit board was replaced (at around five months), our late-model Liftmaster jackshaft opener stopped receiving the RF signal from any distance further out than right up against the garage door. Liftmaster customer service (oxymoron here) agent reading from the standard reply script, insisted it was probably caused by the LED bulbs in the overhead light unit. Changing to incandescent bulbs made no difference. Called back and Liftmaster's second tip was for me to hire an electrician to check every circuit in the house for phantom draws which they said could generate RF interference. I politely declined and called the company that installed it. It was another defective circuit board. The second in one year.
ligito
Oct 19, 2016 02:15 PM
98woody
6.7L Power Stroke Diesel
47
Jun 9, 2014 11:02 PM
3fingervic
Feb 26, 2011 10:39 PM
mworcest
Aug 17, 2007 02:02 PM
skyjack
Jan 10, 2004 03:53 PM
