Batteries go dead
https://youtu.be/V2f-MZ2HRHQ
Other then that there must be some residual effects when this unseen truck made it through the wormhole. Put a set of batteries in and those electrons just go back 16, 17 years.
It might not be the problem, but it should be checked.
The glow plugs are working fine, they come on, and go off, the length of time they stay on is affected by engine temp. They go out faster when its warm outside. Usually too fast to get from the key to the front of the truck to read the meter.
Keep in mind this truck sits in a garage, its rarely dealing with a super cold start. The coldest Ive seen the garage get is around 50 degrees over near the one door. The place has a heated floor that's powered by the boiler in the house 80 feet away. Its not meant to 'heat' the building, just keep it from freezing in there. This winter has been pretty warm, its likely in the mid 60's in there right now even though its only 29 degrees outside.
Today was the third day it sat, before retesting the glow plugs, the battery voltage over that period dropped .01 volts per day.
There is no significant residual draw,
The glow plugs are not staying on, and the relay is working as it should.
The alternator has been tested and retested,
the starter draw is normal.
Having the second truck gives me a baseline to compare to,
I bought the second truck a pair of batteries, changed the oil and filter, pumped the fuel tank and changed both fuel filters today.
It started up after about 10 cranks and idled fine. No codes, no check engine light, etc.
I pulled all four wheels, took all four down to the tire store and had four new tires mounted up. I checked all the caliper slides, topped off all fluids and took it for a ride.
So far so good. I ran it about 30 miles this afternoon mostly at slower speeds on back roads to give i some run time.
It charges fine, everything seems to work as it should.
The two batteries I used were the two 750cca Interstate batteries that came from the other truck. After driving it today the battery voltage in that truck after being parked for about an hour is 12.42v.
The batteries were right off the charger from last night, they were at 12.55v when I put them in the truck. I started and stopped it about four times today and drove it for about two hours while running several errands today. The second truck is showing a .028 amp draw on the battery sitting. Most of today's driving was with the lights and wipers on with the radio playing. The longest sit time was while at the notary getting the tags. Maybe about 40 minutes or so. It seemed to start fine each time.
The only thing I found odd is that the windshield had some oily looking droplets all along the top edge, they were clear and smeared when touched. I thought at first it was water leaking but they weren't water. More like oil. I washed the windows and nothing reappeared. The droplets were slowly running down the glass on the inside but only at the very top. The defroster didn't dry them up or affect them. Maybe something from the plastic gassing off?
I ordered a new fiberglass cap for the second truck, until it gets here I parked that truck down back in the other garage. They told me four to six weeks on the cap.
I didn't plan on buying the second pickup, but it was cheap, and had low miles. Too cheap to pass up.
I am really looking for an older 300 6 cylinder manual trans truck, but it has to be low miles and clean.
No proof of life, I’m done.
The charge volts aren't the problem, the problem is that the batteries simply do not gain charge when the engine is running even though there's obviously battery voltage and amps at the terminals, even if I leave it sit at high idle for an hour. The voltage in the battery is lowered to 12.15 on the first truck, and 11.99 on the second truck. The second truck recovers battery voltage after about 16 minutes, the first truck does not, the battery is only up to about 12.22 after running for a hour. The charging voltage at those batteries is 14.4 to 14.7 volts. When I shut the truck off, the battery voltage goes from 14.7 and quickly drops to 12.3 or so, and will continue to drop if not fully charged. With or without the cables connected. Its as if the truck is using more power than the system can provide.
Both trucks revert to a high idle on their own if left running. They jump up to about 1000 to 1100 rpm.
Both trucks have the 110a alternator
Truck 1 was built 11/02, Truck 2 was built 1/03.
The only real difference between truck 1 and truck 2 is that #2 has heated seats
.On both trucks, with the engines warm, and the glow plugs off, if I turn on the headlights, heater blower, and radio the battery volts drop to only 12.15 or less at idle.
Even with fully charged batteries, on both trucks, the headlights dim at idle at night. If I connect a trailer, the added lights and onboard battery drop the charging voltage to less than 12v, although the amps climb to near 100 with the trailer brakes applied. None of this happens with my 1997 F350. If I were to only drive at night all week, the 03's would both likely go dead pulling the trailer with the lights on. The alternator simply does not keep up.
Both trucks have .023 and .024a of battery draw at rest.
Truck 1 starts faster than truck 2, Truck 1 starts almost instantly if the cranking speed is high enough, truck 2 takes about 3 or 4 revolutions to fire up.
I haven't done any serious testing but truck 2 seems harder on fuel.
I'm going to look at an 04 F350 tonight, its a low miles truck that go hit and repaired. They changed the bed but it didn't get repainted. The guy drove it here from out west and his neighbors are giving him grief over owning a diesel so he has to sell it. It'll give me a newer long bed with low miles. Its supposed to only have 23k on it.
The only drawback is that it won't match any of my other trucks which are all either black or white, this one is silver.
I wish it were an older model but for the price, I can always paint it, then flip it to make a few bucks on it.
If the chargers were at fault I'd also be having issues with all my other vehicles and batteries.
I've also bought and tried three different battery maintainers, all which seemed to be about the same with the exception of the
Schumacher SC1319 which overheated constantly and never seemed to shut off. It wouldn't handle two batteries. Which has been another issue on trucks with two batteries.
In order to put them on a maintainer when parked, the batteries have to be disconnected or at least one needs to be separated so two maintainers can be connected to keep both batteries fully charged. Its not a big deal on a vehicle that's going to sit for say 6 months or a year, but its a royal pain if its only sitting for a few weeks.
The best guys on this forum have asked for pics of the situ and your not doing it.
Why the resistance of this simple request.
You either want help or want to tell us about all the cheap 6.0s your buying.
Which is it?
