Is there a difference between Injector harnesses?
Old Dec 30, 2019 | 06:56 PM
Restlesswildman's Avatar
Restlesswildman
I have been having an miss from time to time on my EX. After installing a new turbo, I got low voltage dtc's on cylinder 2 and 5. I know I have a good FICM and injectors. With 272k on the clock, I thought it might be time for an new injector harness. Does anyone know the difference between the following p/n's? early 03' #3C3Z-9D930-AA , 04' 4C3Z-9D930-AA and 5C3Z-9D930-A. I can get the last p/n in an aftermarket flavor at a very reasonable price. The 1st two p/n's are only available from Ford and are three to four times the last p/n,
I looked in the tech folder and used the search function and came up empty...
Old Dec 31, 2019 | 05:04 AM
Yahiko's Avatar
Yahiko
Not ssure on the part numbers.
I got mine from Ed at FICMrepair.com
They did make an update. You end up moving one of
the bolts and studs to change the location of the mount.
I think it dome to remove some wire stress.
I have no complaints.
Old Dec 31, 2019 | 10:43 AM
F350 1990's Avatar
F350 1990
Interchangeable other than hold downs/plastic mounts...........warning: the FICM connectors on some of the aftermarket variants are flaky.........
I'd personally stay with the higher quality Motorcraft (International) product..........
Old Dec 31, 2019 | 07:43 PM
SmackDaddy's Avatar
SmackDaddy
The first one is $188. Pretty cheap to save a FICM and have the correct harness for your year model.
https://parts.autonationfordwhitebea...ly-3c3z9d930aa
Second one is $233 and not your year model
https://parts.autonationfordwhitebea...ly-4c3z9d930aa
Third is not much different in price and there are two part numbers
https://parts.autonationfordwhitebea...r=5C3Z-9D930-A
I’d stick with your year model and Motorcraft for this. I replaced mine a few years ago.
Old Dec 31, 2019 | 09:47 PM
Yahiko's Avatar
Yahiko
The one I ordered was a Motorcraft one and I got it from Ed at >>>
https://www.ficmrepair.com
robinsonpowerstroke
Nov 5, 2012 09:57 PM
holdtyte
Aug 26, 2012 03:05 PM
stvwrld
May 25, 2011 07:20 AM
caseydudem
29
Oct 19, 2007 09:16 AM
JARP
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Aug 12, 2004 04:23 PM
