Front end rumble
Old Dec 28, 2019 | 08:37 PM
rufushusky's Avatar
rufushusky
Front end rumble
Hey all, got a front end rumble in the truck in the sig. Seems to be from the passenger side, I was thinking a wheel bearing but the rumble didn't go away when I locked the hubs and engaged the transfer case. Only notice the rumble and vibration between 48-60 mph. Vibration smooths out after 60 but rumble continues. No other noticable symptoms . Anything else I can check?
thanks in advance
Old Dec 28, 2019 | 08:43 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Bearings in the wheel hubs are my first guess. Get the tire in the air and feel if it rolls smoothly. Also grab the tire at 9 and 3 and yank it around with extreme prejudice, see if it's loose.
I'm thinking the needle bearing are ok since engaging the 4WD didn't change the sound.
Old Dec 29, 2019 | 04:58 PM
rufushusky's Avatar
rufushusky
Got a chance to get the front end in the air, slight grind on the passenger side, no wobble on the wheel but oh boy did we have play on the backside of the hub. Could push the u Joint up and down a good 1/16th or so either way. Thanks for the help.
Old Dec 30, 2019 | 03:24 PM
countrycar's Avatar
countrycar
Along with the hub bearing replacement, you'll have to replace all the seals on both sides as well. Check the spindle axles for wear, they might need to be replaced if the inner bearing damaged them. If they're not to bad, you might get away with hiting them with some emory cloth. Also, for future reference, these non serviceable hub bearings can be greased as well.
jimlj
May 26, 2017 01:42 PM
ford, excursion
Feb 11, 2014 11:06 PM
HogginNboggin9
Jul 17, 2011 10:20 AM
FSJ-EARL
May 25, 2010 01:41 PM
MBBCop
Feb 15, 2007 10:02 AM
