Help Doing coolant flush and low volume
Old Dec 30, 2019 | 03:14 PM
Yahiko's Avatar
Yahiko
I have an easy way to get at the passenger side drain plug..
Get you hands on one of the long leg ball end allen wrenches that fit the plug. Cut the short end off so you have just a nice straight tool. Save the
end for other projects. Next get some of the mastic heatshrink that will fit over it and shrink into place leaving the ball end and top exposed. The reason
for this is to give you insulation or you can just disconnect both batteries to skip this step. You don't have to remove the starter once you have this
tool in you kit. You can use an open end wrench or the box end to unscrew the plug. The first time tends to be the worst. It's also a good idea to
have a magnetic pickup for the time you drop the plug between the starter and block. The plug almost always goes back to the flywheel cover and
the magnet pickup will get it out for you.
Here is how Srmastertech shows how to do it. I do a slight modified and don't use the chemicals unless you need to.
Old Dec 31, 2019 | 03:21 PM
Brian Hanks's Avatar
Brian Hanks
Yeah. I think I will use that and plan to install a fumoto like I did on drivers side. That was plan anyway. once and then easy.
I saw one recently that was a banjo style with right angle connection it was pretty cool.
Old Dec 31, 2019 | 07:15 PM
Yahiko's Avatar
Yahiko
I think you really want to use that style on the passenger side do to the starter being in the way.
Qwazert
6.2L V8
Dec 9, 2019 05:30 PM
mh5500
Jun 5, 2010 09:14 AM
renoduckman
16
Mar 3, 2009 06:22 PM
irvinf
1983 - 2012 Ranger & B-Series
Feb 12, 2004 02:48 PM
fhartell
Jan 2, 2004 02:21 PM
