4R100 overdrive burnt
Old Dec 27, 2019 | 05:33 PM
Zac Wahl's Avatar
Zac Wahl
I have a 99 F-350 with a 4r100 that I just pulled out because the front seal was leaking on the pump. While I was in there i decided to check the clutch packs and found overdrive severely overheated but all of the other clutch packs were in perfect shape, could still read the print on the others. I have a new o/d clutch pack and intend on putting the trans back together this weekend but wanted to understand why I lost o/d first and what to look for while I have it apart. I have rebuilt one successfully once but its different tearing down a working transmission and diagnosing one. Any help would be much appreciated.
Old Dec 27, 2019 | 10:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The only thing that I can think of is that the truck was working at or above it's maximum rating and was shifting in and out of overdrive frequently. This will overheat and burn the overdrive clutch.
Old Dec 30, 2019 | 12:51 PM
Zac Wahl's Avatar
Zac Wahl
I appreciate the response! I know very little about the past life of the trans. It does have borg warner clutch packs and the replacement snap ring for the od piston so i believe it is rebuilt. Hopefully it will be fixed with the new parts. The last thing i have to do is check the valve bodies. THanks again for the response!
Zac Wahl
Dec 27, 2019 09:52 PM
BRay09
Feb 7, 2016 01:32 AM
Tibbits
Oct 17, 2009 01:34 PM
broncolou
Mar 15, 2009 06:13 PM
OldSchoolRodz
Nov 23, 2004 08:44 AM
