Dump valves
Old Dec 27, 2019 | 01:06 PM
LiquidCowboy's Avatar
LiquidCowboy
Dump valves
Ok so I'm building a blower setup, and been doing some reading and keep coming across dump valves for the tranny. Think I'll need it? 400/408 11:1 before boost 6-71 & C6
Old Dec 27, 2019 | 06:47 PM
85e150's Avatar
85e150
A 6-71 on top of 11:1 compression.
You need to go back to blower motor school.
Old Dec 27, 2019 | 08:40 PM
LiquidCowboy
Ever see a blown 400 Ford or one that n/a turns 7200 without coming apart?
I'm asking questions because I need to know.
Also my DCR pre boost (wasn't asked of me) is in the low 9s
Back to transmission though, will it be necessary to need a dump valve or just launch without it?
Old Jan 3, 2020 | 06:33 AM
Briansshop's Avatar
Briansshop
What trans? Target ET?
Old Jan 3, 2020 | 11:44 AM
LiquidCowboy
C6 and weighing 4330 I'd like 10s
Old Jan 3, 2020 | 01:08 PM
Briansshop's Avatar
Briansshop
E4OD here,so basically a C6, no brake, low 10s otw to 9s soon.
Your first post says 11:1 "before boost",btw.
Old Jan 3, 2020 | 01:17 PM
LiquidCowboy
Yep, 11:1 before boost (static) 1.71ch flat tops, 4.030 bore 4.055 gasket, 4 stroke, 72cc heads, 6.58 Molnar h beams 10.290 deck height. Setting up rev limiter on 7200.
​​​​​​DCR comes down to a fairly decent number I can run on pump gas but will end up going e85 or Methanol when I put the big pulleys on it.
Old Jan 3, 2020 | 01:19 PM
LiquidCowboy
My cam card has run away but the pn is 10320509 from lunati
Old Jan 3, 2020 | 08:59 PM
Briansshop's Avatar
Briansshop
I think you should be more concerned about that motor combo then any trans issues.
Old Jan 4, 2020 | 10:25 AM
beartracks's Avatar
beartracks
Take picutures! I love explosions.
Old Jan 4, 2020 | 12:10 PM
LiquidCowboy
I'll post video here and in the 335 series forums.
Old Jan 5, 2020 | 03:30 PM
Blurry94's Avatar
Blurry94
If this were a nitrous build then the CR ratio would be good...not so much with forced induction though.
bobaderson244
1997 - 2003 F150
Mar 26, 2011 04:38 PM
shaggy5935
May 27, 2009 03:29 AM
samboman
Mar 17, 2009 05:56 PM
Freightrain
May 10, 2006 08:06 AM
parks911
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Apr 3, 2004 05:16 AM
