Sponsored by: Auxito
door panel
Old Oct 11, 2003 | 11:14 PM
MikeF1185's Avatar
MikeF1185
door panel
Any tricks to removing the door panel/card (interior). Whoever worked on the truck previously did not install the driver side properly. I know with any vehicle it is held in by plastic clips that break like twigs, so are there any secrets before i start to prevent this from happening?
Old Oct 11, 2003 | 11:37 PM
alpine7572's Avatar
alpine7572
There are about 3-4 screws that hold the panel in. Once they are removed then lift the door panel upwards. Do NOT PULL. If you do you will break the tabs. So Lift up.
Mike
Old Oct 11, 2003 | 11:39 PM
LxMan1's Avatar
LxMan1
It is not like the older doors.
1) Remove the Vertical trim piece. It just pops off.
2) Pop out the Switch panel where the Power window and door lock switches are.
3) pop out the trim piece behind the door ****.
4) Remove the Screws behind the vertical and door ****.
5) lift the door panel straight up about an inch and it will come right off.
No clips to break or replace.
Jimmy
Old Oct 12, 2003 | 04:28 PM
triton_2002's Avatar
triton_2002
If you have manual windows, there's a torx screw in there. The cover on the handle comes off and swings out of the way.
Old Oct 12, 2003 | 06:07 PM
Racerguy's Avatar
Racerguy
I took pictures as I was removing a door panel the other day.
Maybe tomorrow I'll get a chance to get them on here.
Old Oct 12, 2003 | 10:24 PM
MikeF1185's Avatar
MikeF1185
thanks for the tips guys. now i just need the motivation to do it during the day. can't really do it at night b/c i can't open the driver side door very far when it's in the garage
Amicus
Nov 19, 2014 02:27 PM
tylert1976
Dec 5, 2012 11:50 PM
arrowheadfred
Nov 8, 2010 10:23 PM
chicagodragon
Apr 16, 2010 10:50 AM
billy13
Dec 14, 2009 10:29 AM
