Sponsored by: Auxito
Tips on doing Compression test
Old Dec 25, 2019 | 09:26 PM
Murkin MurDock's Avatar
Murkin MurDock
So I’m gonna do a compression test on my motor because after I did spark plugs I noticed I had oil on the bottom half of spark plug. The cop is dry by the way.
so to do compression test, I know need to take all plugs out but someone told me I have to disconnect my ignition system, or hold the gas pedal all the way done to the floor. And I don’t under stand why I need to poor a little oil in the cylinder head before I do it.
and can’t I buy a switch so I can start the truck with out being in the cab?
Old Dec 25, 2019 | 11:48 PM
Bluegrass 7's Avatar
Bluegrass 7
No need to put oil in the cylinders because you want to know the pressure as it is, not help it with an oil seal.
Pull all fuel injector connectors off of so fuel is not sprayed and blown out of the plug holes lest you have a fire situation from spark.
The throttle has to be opened at least 3/4 to allow enough air into the cylinder under test to compress and free up the other 7 for faster spin.
If any cylinder is Low >>>>> then put a small amount of oil in to see if the compression pressure increases significantly. That is the value of putting the oil in in that circumstance. It would suggest a ring seal issue.
if the compression is low, listen in the intake and exhaust for leakage. This would suggest valve seal leakage.
An air leak heard in the crank case is rings/and or a piston issue.
A blown head gasket will influence the pressure reading. Into the next cylinder or into a coolant passage.
Use common sense on these possible results..
All this make sense to you?
Good luck..
Old Dec 26, 2019 | 05:12 AM
Tedster9's Avatar
Tedster9
Thing is modern manufacture engines aren't worn out after 75k like they were back in the day. Not sure that a compression test has all that much utility on anything made since the 1980s or so. Could be wrong.
Technically speaking the engine is supposed to be fully warmed up, by oil temperature indication. This is widely ignored because nobody likes working on a hot engine. Usually checked first without adding any oil to the cylinders, and then about a tablespoon or so if low, to see if the problem is rings or valves.
Yes, you'd want a remote start switch, unless you've a helper.
Old Dec 26, 2019 | 09:42 AM
alloro's Avatar
alloro
Warm the engine before you start taking the plugs out. The oil is only necessary if any of the cylinders give a low reading. If you get a low read you then squirt the oil in and take another reading. If the PSI goes up it's an issue with the rings, if it doesn't then the issue is with a valve.
Old Dec 26, 2019 | 10:40 AM
Clutch5sp's Avatar
Clutch5sp
Learned a quick & easy compression test to do. Used it during pre-firing my engine. Whew...it was good.
Unplug the crank sensor connector so the engine won't start
Turn the ignition key like trying to start it and listen carefully for maybe 20-30 secs
duh unna unna huh duh unna unna huh <-----is the sound of one or more cylinders having less compression than the others.
unna unna unna unna <-----is the sound of cylinders all being the same.
It's OK to say that I may need a doctors office visit for diagnosis
Old Dec 26, 2019 | 05:07 PM
Murkin MurDock
Thanks for all the tips/ advice I’m about to do it when I get home.. and clutch5sp your speaking my language lol.
And is the crank sensor behind the ac pulley that you can see from passenger wheel well?
Old Dec 26, 2019 | 07:08 PM
pdqford's Avatar
pdqford
Instead of pulling all the fuel injectors just unplug the crank sensor. That will keep the ignition from firing and keep the fuel injectors from firing.
The oil you found on the bottom half of your spark plugs could be from a bad camshaft cover gasket letting oil leak down into the plug well.
Old Dec 26, 2019 | 10:09 PM
Murkin MurDock
If I was leaking oil from there wouldn’t my cop have oil on it??
Old Dec 28, 2019 | 12:29 PM
Clutch5sp's Avatar
Clutch5sp
The crank sensor is at the harmonic balancer 7 o'clock next to the AC comp. Get it from under the truck. Typical Ford connector that will fight you to unplug. Find the clicky tab and pull it loose making sure it doesn't get caught up in the belt while testing.
Old Dec 28, 2019 | 05:48 PM
pdqford's Avatar
pdqford
No. COP is not that far down into the spark plug well.
Old Dec 29, 2019 | 12:06 PM
alloro's Avatar
alloro
If it's easier you can also pull the fuel pump relay to keep the engine from starting. This has the added benefit of turning off the fuel supply. In fact I usually start the engine and then pull the relay so the fuel pressure bleeds off and you're not working around or on a pressurized fuel system. I'll keep the relay out until it's time to start the engine after the work is done.
1954wrecker
20
Jun 27, 2018 09:16 PM
Andrew Rice
4 Cylinder Engines
Jan 26, 2018 02:58 PM
Methodical_1
Feb 4, 2013 06:20 PM
FirstFord89
Sep 14, 2009 02:22 PM
Boltgunner
17
Feb 6, 2006 10:58 PM
