Trailer backup light voltage
Old Dec 23, 2019 | 11:19 AM
sealer700's Avatar
sealer700
I want to mount a 20" light bar to my salter and it requires a 9-32 volt output from circuit. Will the trailer plug be enough power. 2019 f250
Old Dec 23, 2019 | 11:37 AM
Ls1itldo's Avatar
Ls1itldo
Yes, it is 12v and should have plenty of power for an LED light bar.
Old Dec 23, 2019 | 11:39 AM
Cletus Hogwallop's Avatar
Cletus Hogwallop
Trailer connector will supply 12v.
But volts are not power, watts are. Watts are voltage multiplied by the amps. How many watts does the lightbar require? Does it have a spec sheet with it (or online)?
Old Dec 23, 2019 | 11:52 AM
Ls1itldo's Avatar
Ls1itldo
It would be a hell of a 20" light bar to pull more amperage than the 30 amps available on the trailer plug, especially if it is a LED light bar. Yes, I understand the difference and relation between wattage, voltage, and amperage. Now, if you start talking about Laplace's equation or Fourier transforms, I'll need to grab my old textbooks.
Old Dec 23, 2019 | 02:10 PM
Douglasmatthewc's Avatar
Douglasmatthewc
As long as your trailer has a battery inline the truck will see the voltage and supply power. These newer trucks only supply power if it sees a voltage ( battery ) in the circuit.
Old Dec 23, 2019 | 02:33 PM
crewzer's Avatar
crewzer
Lightbulb
The trailer backup light circuit in the 7-way connector appears to be protected by a 10A fuse (engine compartment power distribution box #84).
If you have them, one of the upfitter switches might be another option.
HTH,
Jim / crewzer
AMECG34
Oct 16, 2017 06:44 PM
how2
2015 - 2020 F150
Jun 28, 2015 07:57 PM
KHADIJE22
6.4L Power Stroke Diesel
Mar 24, 2012 09:55 AM
TXtinct
Feb 24, 2012 10:11 PM
freeholden
Feb 2, 2010 09:19 PM
