6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Trailer's light
Old Mar 22, 2012 | 08:45 PM
KHADIJE22's Avatar
KHADIJE22
Trailer's light
I have f350 2008 super duty 6.4l
The signal light &the brake light are working fine on the trailer but the trailer's light does not turn on.
I checked all the fuses,the wires all are fine.
What could be the problem
Any suggestions?
Thank you in advance
Old Mar 23, 2012 | 03:58 PM
senix's Avatar
senix
sounds like a ground problem to me. I would hook at jumper from truck to trailer and see if that helps.
I would also test for power at the 7 pin connect for the trailer lights.
Old Mar 23, 2012 | 08:07 PM
KHADIJE22's Avatar
KHADIJE22
Hi
I did check the pin 7 has no power
I hook a jumper from the truck to the trailer the light did go on
Thank you
Old Mar 24, 2012 | 05:15 AM
senix's Avatar
senix
That is great news.
Old Mar 24, 2012 | 09:55 AM
Leonandlisa's Avatar
Leonandlisa
I know you said you checked the fuses but to be clear you checked the fuse on the drivers wheel well under the vacuum pump correct? It is one of the large square fuses with the clear plastic top. I had the fuse blow when I had a short on my travel trailer, it took me a while to find as I was looking in the wrong fuse block.
Leon
56Jimmy
All Things Towing
25
Feb 21, 2019 06:00 PM
Pablo-UA
1983 - 2012 Ranger & B-Series
Nov 14, 2014 02:42 PM
freeholden
Feb 2, 2010 09:19 PM
jbrianas
Oct 11, 2007 10:23 PM
Jim_McGregor
1997 - 2003 F150
Jun 5, 2002 09:11 PM
