Transmission Help
Old Dec 17, 2019 | 10:25 AM
02PS73's Avatar
02PS73
Transmission Help
OD light was flashing scanned codes only code that showed was VSS replaced sensor worked for about 5 miles then light and eratic shifting started again any ideas?
Old Dec 17, 2019 | 10:54 AM
Walleye Hunter's Avatar
Walleye Hunter
What are you reading it with? Only specific readers will read our tranny's, AE is one of them. If you describe your erratic shifting it might be helpful to the guy who really knows these tranny's.
Old Dec 17, 2019 | 11:46 AM
02PS73's Avatar
02PS73
I scanned it with a snap on scolus
Old Dec 17, 2019 | 08:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A VSS code can be set by a bad VSS, a damaged wire between the VSS and the PCM, or a problem with the ring gear. It is one of those three.
finn12
Jan 24, 2017 12:39 PM
juiceymustang
20
Jul 15, 2014 03:30 PM
F350long
Oct 1, 2007 09:14 AM
MikeSDK
Nov 17, 2006 02:06 PM
MARK7164
Mar 30, 2004 08:02 PM
