Can Dealers add TBC to '18+ yet?
Your helpful threads have already told me it is possible to DIY install the TBC on 2018s on up, which are different than previous model years. My question is has anyone gotten a dealer to do it to either make the sale or after you bought it?
Thanks for all your help, btw...
Scott
Scott
So I go look at the truck tomorrow... Dealing with a "Sales Manager" -- it's an XL with upgrades, btw... Have seen where Ford is coming out with a fix that doesn't require a change-out of the Fuse Box, so maybe they put the old box in later '18s, as this one is...? Would like to get them to commit to enabling and installing a factory TBC unit, so one way or the other this will be a negotiating point....
Thanks,
Scott
Thanks,
Scott
There is a service action that instead of the replacement fusebox they can do a fuse tap to save the customer some money. It's still not cheap, it's right around 300 in parts and 1.5 hours shop rate. Plan on 500 or so to add TBC to a non TBC equipped truck. I suggest finding a truck with the base tow and TBC or max tow.
Hey Scott,
Here’s a video on adding the TBC to an F150 equipped with the trailering package. It appears that the wiring harness is already there.
once setup, likely looking at a Forscan update to the trucks computer...as seen elsewhere on the forum.
I’m going to need to do this as well. if you search Tasca Parts dot com, They sell the TBC controller for less than 90 bucks.
Thanks for the help guys,
Scott
Hey Scott,
https://youtu.be/XnhedTESYLo
Thanks,
Scott
So I'm closing this thread out with the answer. We bought a Late Build 2018 today - Build was Sept of 2018. Ford has started putting the Battery Junction Box that has the 30A fuse in slot 24 back in the F150s, at least anything with a tow package or even the hitch, don't know if it is ALL (as in a base XL will have it) or just those with some sort of tow option. My bet is they went back to all. I suspected this might be the case after reading: Ford SSM 47320, which instructs dealers to no longer replace the BJB for folks that wanted a factory or after market trailer brake controller installed, after the fact, but instead use a new Ford work-around wiring loom to give power to the TBC plug.
Our truck had the 24 BJB slot with a 30A fuse in it, so other than needing to get the '18 version of the ITBC, it's back to what folks have been doing in previous years, or asking their dealer to do... Plug and Play and enable via PCM update...
Thought you all should know what I found personally...
Thanks for everyone's help!
Scott
Scott
The 2019 part breakdowns are showing a different SJB for non trailer tow package trucks still. Also worth mentioning is trucks without the led bed lights are missing the extra wiring in the cab and that shows a different harness. I believe ford will maintain these parts for low optioned trucks and fleets as it only makes sense. It's so rare these days to see a truck without a tow package most people should have the fuse in spot 24 and be able to add the TBC just fine or add the jumper. Also word of caution the 2015-2017 TBC has a different part number for the TBC and the 18+ can not use the old style. Make sure you get the correct part numbers.
Good intell. as usual - it would be cost prohibitive to have different or custom wiring harnesses, unless there were masses ordered as base models... But swapping out the BJB that enables that harness part? I guess I could see that...
Interesting note was a long time sales person at the dealership came by when we were waiting on final delivery and said the Optioned Up XL was the best value going -- so maybe Ford is trying to make that less so appealing??
Dunno, just know what WE got is a rippin' truck...!
Scott
Scott
I Never truly closed out this thread (as in what finally happened). My friend bought the TBC unit online for like $90 delivered (Ford packaged part) #GL3Z-2006-CB or JL3Z-2C006-AA and installed it the "hard way" method where you take most of center dash apart, but minimizes probability of breaking tabs, etc...
And I bought This cable for Forscan off Amazon:
And then Downloaded the required Driver to talk to my Win7 laptop. AND upgraded my Forscan to a temporary developers license. And from the videos and whatnot, wrote down these steps, that really should be in your guys' Tech Section:
Need to load drivers and upgrade (free) to Forscan Developer's License
Connect cable to Truck and PC, run Forscan Only on laptop and turn Key to On in Truck
(Forscan will do all the connection stuff automatically, and ask you if you have a switch for CanBus speed) - Note, in the Cable instructions, follow the picture for the VINT module for switch setting!
Under Chip Icon
Select IPC Module Configuration (blank)
Hit Play symbol
Select Trailer Brake Control Module
click on Edit Selected box
Select Enable
Hit OK
Click on Write box
Say Yes when prompted do you want to do this?
Should tell you to cycle key off and then on again.
Select OK and Done.
Then Do Same for Trailer Brake Controller Gain Setting.
(and we did a number of other Enabling and Disabling of things while in here, btw!)
After all done Hit Stop.
All the Best my F150 friends!
Scott
Under Chip Icon
Hit Play symbol
Select Enable
Hit OK
Click on Write box
Select OK and Done.
Scott
