Riddle me this.... Payload.
i haven't towed yet with my Excursion, only owned it about 3 weeks and probably won't be towing with it until spring. I will probably put air bags on it just to help out. But that doesn't increase payload capacity. Just wondering why the hype of knocking me Expedition payload, but the Excursions are just fine? (I notice how some bash the new F150's constantly about only having a payload of 1600ish pounds) Please help me out, and answer why? Trust me, I will be getting a bigger trailer soon and will be using my Excursion to pull it. But just curious why the 1/2 tons get such a bad wrap?
I took the same rental TT on the same trip in 100*+ weather with my 2003 Yukon XL and 2005 Ex. The diff in the Yukon overheated and puked out most of the gear lube. The Ex takes it in stride.
Part of the reason for the F150 truck's getting a bad rap is not the truck itself. It's the people that know little to nothing about towing dynamics and rated load capacities of the vehicle they own. They purchase a F150 with let's say a 1600 lb payload capacity then hook up to a fifth wheel camping trailer that puts 2000, 2500, lbs of pin weight on the truck....then post up on a forum and talk about how great it tows their trailer. They are overloaded and many times, (don't even know it or worse, don't care) and then start a new post on the forum....."What's the Best brand of Air bags or helper springs". Every vehicle has a limit, actually, several limits....and it is the owners responsibility to know the truck's limits and hopefully, abide by them.
Been there, done that, hauled horses with a tow vehicle which could nominally pull the load, but boy, the transmission went fast.
This tells you how much people and cargo you can carry in the truck, including the tongue weight of a trailer.
Similar trucks will differ. For example my F250 small block has a payload of like 3,100 pounds. Mom's F250 big block, flatbed has a payload of around 1,000 pounds. The trucks have the same axles, springs, brakes, and tires and the GVWR is the same, but Mom's truck is so much heavier it has a much smaller payload. This is also why an F150 may have a bigger payload than an F250 diesel: GVWR - curb weight.
What you get with the Excursion is a higher Gross Combination Weight Rating(GCWR).
GCW(missing the "R" on purpose) = truck curb weight + trailer curb weight + payload(all people and cargo in the truck and trailer)
GCWR is the maximum sum of the previous equation a truck is rated to tow.
So (pulling numbers out of thin air for illustrative purposes) the Expedition may have a GCWR of 14,000 - 16,000 pounds, and the diesel Excursion may have a GCWR of 18,000 - 20,000 pounds. It's easy to see the advantage here, even if the payload is less on the heavier truck.
Towing 7,600 pounds GVWR your tongue weight should be less than 800 pounds. Well within your payload rating. According to the specs on this site, '03 Expedition maximum towing capacity is 8,900 pounds. The Expedition was fine to tow that camper.
The hype of bashing the Expedition is simple ignorance: Expedition Small. Excursion BIG! Grunt,Scratch,POST - and not always in that order.
Legal liability is real when going over ratings, but very basic things the legal beagles miss...and are often guilty of: Anyone bumper towing over 5,000 pounds (or 6,000 depending on hitch class) needs a weight-distributing hitch or you are legally negligent in an accident. Anyone towing a trailer over 10,000 pounds Gross Vehicle Weight Rating(GVWR) needs a Class A CDL - that's Rating (what it can weigh), not actual weight.
(This is why so many big trailers are rated at 9,900 pounds GVWR or have a 9,900 pound suspension option)
I agree with you 100%! I was just asking the question. I do agree alot of people will buy a new F150 or something like that and expect to tow a 12000 pound trailer cause either the camper place or auto dealer said they could. I am amazed(well not really anymore) of people's ignorance of what they can safely pull. I have seen plenty of them pulling a trailer WAY to big for their vehicle, but continue to do it cause they can. I got my Excursion 1, because I have always wanted one, 2, cause its better to be safe than sorry and to be able.to tow further without any worries, and 3, cause eventually we will be getting a newer bigger trailer( our current trailer is a 2018 Outback 293UBH) and didn't want to buy a truck just to have to go buy another one in a year or two.
i was just asking that question to see what answers I got. I have seen plenty of even bigger trucks overloaded too. Was just curious, that's all.
Now, I realize this is the bumper pull section and not the fiver section of the forums, so most of that doesn't apply to the trailers being towed here, but I wanted to make sure the clarification was out there, incase people though they needed a CDL for 'any' trailer over 10,000 lbs.
I love it when internet know-it-alls come on spouting stuff off and are wrong or making stuff up.
I find it rather humorous.
