Gonna need to tow a skid steer, Skid is 8500 to 9000 pounds w bucket. Not sure on the weight of the trailer (bumper pull) as I dont have that yet so im guessing 2,000 pounds for the trailer? Little extra weight for tie down chains and such. and maybe a attachment for the skid.
So im guessing around 11,500 to 12,000 total?? Most towing will be local, and then only occasionally. And maybe once in a while go an hour farther with the setup for service and repairs. Will a 6.2 work or am I needing a 6.7 diesel?
I think you will be fine with a 6.2. That falls within the tow specs. Especially if it is occasional and mostly local. There have been lots of posts from guys towing that weight or higher with a 6.2. Might suck a lot of gas though while towing. Diesel would be an easier tow for sure but if your not towing long distances regularly it wouldn't be worth it to me. That's a personal choice you have to make.
I also agree you would be fine if you get the 4.30’s
As far as the trailer, I would assume you are looking at a 14K GVWR, so I would use 3K as the dry weight. I say that based on specs from a 16’ 14K PJ trailer with no options.
For the amount you're saying youre going to pull, I'd do it with my 6.2L. And I'm pulling hills. Will you win a race against a diesel in the hills, nope. Do you need to? that's up to you.
For towing heavy, I would be inclined to say get the F-350 with the 6.2L and the lower gears. This will get you the 6r140 transmission. If you can get that transmission in the F-250 then go with the F-250. As I recall, the only way to get the 6r140 in the F-250 is if you get the 6.7L. Maybe things have changed since the 2017 model year.
you are correct about only getting the 6r140 in the 350, when configured with gas.
It is good to know though. I almost bought a trailer to tow my equipment and found out I would need a CDL. I'm still waiting to see if I still want to do that. I am non commercial but the combined weight pushed me into the CDL requirement. An honest trailer salesman saved me. Knowledge is a good thing.
I had to pick up a T590 a couple of weeks ago with my 24 ft gooseneck trailer that weighs 4k lbs. I took my old faithful 2001 F-250 5.4 with 4:10 gears and a 5 speed. I had to slow down some on hills, but it did fine. With a 6.2 and 4:30 gears I would not hesitate to pull this every day.
I'd definitely opt for the 350 with 4.30 gears. You won't regret it.
This load a couple weeks ago leaving our county fair, was about 16k and it handled very well. I regularly two 10-12K with it and it's nothing short of a pleasure back and forth to the farm.
