Door Chime
Old Dec 9, 2019 | 10:17 PM
Wheelman55's Avatar
Wheelman55
Door Chime
This is a new occurrence on my ‘93 F250, 7.5L
With the key OUT of the ignition switch, the door chime stays on when the driver’s door is open. What/where should I be checking?
Thanks!
Old Dec 9, 2019 | 11:15 PM
marksman76's Avatar
marksman76
key cylinder ignition switch.
There is a little brass ( copper?)
piece that flexs and then breaks, or moves around ( fails)
Old Dec 10, 2019 | 06:30 AM
Wheelman55's Avatar
Wheelman55
Thanks...I will check. Is there a fix for the little brass piece, or is it a “replace the switch”?
FYI I installed a new Ford OEM switch with matching door locks three years ago. Bummer if it’s failed already.
Anyone else with other ideas?
Old Dec 10, 2019 | 11:12 AM
mary-kate's Avatar
mary-kate
As mentioned, there is a little metal contact in the hole that the lock cylinder goes in. If you pop out the key cylinder you will most likely find this piece broken off it's plastic and hanging by it's wire. It's part of the column, not the lock cylinder IIRC. It can be fixed, but I just taped it and pushed it out of the way.
Old Dec 10, 2019 | 11:50 AM
marksman76's Avatar
marksman76
I replaced mine
Old Dec 10, 2019 | 06:04 PM
Wheelman55's Avatar
Wheelman55
Thanks. How do you fix/replace this piece?
Old Dec 10, 2019 | 08:26 PM
mary-kate's Avatar
mary-kate
IDK. I just pushed mine to the side. marksman76 would know since they replaced theirs.
Old Dec 10, 2019 | 09:01 PM
marksman76's Avatar
marksman76
I looked here on forum.
I prefer to pay experienced locksmith to do it.
Xclimation
Apr 17, 2021 10:28 PM
friskyjake
Mar 24, 2017 10:51 AM
Stephen67
Jan 26, 2010 11:20 PM
fordinmudd
Electrical Systems/Wiring
Aug 15, 2006 01:08 AM
speerwurf
1997 - 2003 F150
Apr 3, 2006 06:57 AM
