Torque Specs
Old Dec 9, 2019 | 11:08 AM
JohnNewb's Avatar
JohnNewb
Torque Specs
Hope to install flywheel and clutch today on my F350 223 4spd. I easily found flywheel torque. Anybody know pressure plate bolt torque?
Old Dec 9, 2019 | 08:37 PM
spurredon's Avatar
spurredon
John, do you have a Shop manual? You would really enjoy it.
Old Dec 10, 2019 | 07:45 AM
Beer Fridge's Avatar
Beer Fridge
Here is the Spec page from the 1960 shop manual with published torque specs for clutches and manual transmissions.
And the page for general torque specs for bolt size. The shop manual states, "torque pressure plate bolts to specifications." So, I would go with bolt sizes for torque specs.
Hope this helps.
PBF
Old Dec 10, 2019 | 09:35 AM
JohnNewb's Avatar
JohnNewb
Hope this helps.
PBF
Thanks. I ended up using a general torque chart and specs I found for '61 ford, 25 ft. lbs. If I remember that is a pretty common torque for pressure plate with 5/16" bolts. I replaced the bolts with spec 8 bolts after snapping one off with my swap meet cheap torque wrench. Neighbor with set of manuals loaned me his torque wrench to finish up. On my list today to shop for torque wrench.
1989FordF250
Oct 15, 2017 10:11 PM
ConvertedFord
Dec 13, 2012 08:54 AM
branning
Nov 12, 2008 09:54 PM
BarryMc
Aug 27, 2008 06:27 PM
58ford
Mar 10, 2002 01:14 AM
