torque head bolts
Old Nov 12, 2008 | 09:43 PM
branning's Avatar
branning
torque head bolts
does anyone know,what the torque lbs for the head are for a 95 f150 300 6 cyl
Old Nov 12, 2008 | 09:46 PM
branning's Avatar
branning
anyone know ?
Old Nov 12, 2008 | 09:53 PM
88n94's Avatar
88n94
The Haynes manual says step1 55. step 2 65. step 3 85. foot pounds. 85 ft. lbs. final torque. Always double check and triple check the final torque.
Moore558's Avatar
Moore558
According to Mitchell...
First pass 45-55 ft lbs
Second pass an additional 80-100 degrees
Torque in sequence.
I would suggest using NEW headbolts. I'm also not sure if these are the right specs, so a Haynes or Chilton manual would be a good thing to buy to compare. Hope this helps you.
Old Nov 12, 2008 | 09:54 PM
Moore558's Avatar
Moore558
Those torque specs sounds better than what mitchell has so I'd use that.
