Steering shaft
Old Dec 7, 2019 | 08:08 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Steering shaft
You guys have a good place to buy steering shaft?
mine is very loose st the joint at box on my 2003
Im guessing borgeson probably makes one.
Ive searched and only found info about box and linkage
Old Dec 7, 2019 | 08:18 AM
KubotaOrange76
Edit
thinking back
its a rag joint at the box isnt it?
Old Dec 7, 2019 | 08:22 AM
knotEdog's Avatar
knotEdog
I just replaced my clock spring assy. and noticed my steering wheel was a bit loose. I went with a complete refurbished unit. from DaKidCamaros on Ebay all bearings new, new shift plunger, airbag, multi control lever, and shifter handle with o.d. button, ignition actuator, clock spring assy., and tumbler assy with two keys. Cost me $300 but I am finishing up a Cab-Off restoration of my 02 F350 Super Duty.
Old Dec 7, 2019 | 11:03 AM
KubotaOrange76
Nevermind
just verified its the box
ill tighten box an 1/8” or two while i save for redhead
Old Dec 7, 2019 | 11:22 AM
Colorado350's Avatar
Colorado350
Originally Posted by KubotaOrange76
Nevermind
Im sure you know this but mark the nut, bolt and box before you start the adjustment then you know your start point.
Check out West Texas Offroad they can rebuild your box and even port it so IF You wanna do hydra assist down the road you can without pulling the box again.
Old Dec 7, 2019 | 01:34 PM
KubotaOrange76
Good call
i remember west tx from my 4 wheeling days. Cool to see they still around.
chukar
Mar 13, 2016 12:05 PM
SCRebel
Oct 4, 2011 01:18 PM
nrw1717
Nov 27, 2007 10:42 PM
Jtown150
1997 - 2003 F150
Mar 9, 2004 11:59 PM
