Central Oregon New Guy
Just wanted to introduce myself. I’m the newb as of tonight. Been a Ford guy since the latter part of my teens having owned a couple of Fairlane sedans and coupes, Rancheros, and a Fairlane wagon.
Miss my big block wagon the most though. Top-loader, sleeper. I’m sure cops hated me but they never caught me!
20 years and a couple of Ford pickups later I find myself with a 2000 F250 SD, Super Cab, 7.3 PSD, long bed, automatic.
Since it’s my first Diesel I’m learning a lot quickly. I have good personal technical connections but they have mostly Cummins experience.
My 2000 only has 136k miles and generally seems to run fine but I want to do a few mods next spring. I’m thinking Hutch and Harpoon mods as well as gauges, 6637 air filter and cold air intake. I’ve heard tell of a cross over hose for the high pressure oil system to help even out pressure on both banks of the injection system.
Driving-wise, it’s kind of a daily driver during the winter but will mainly be used to tow my camper during summer and I’ll drive one of my Jeeps as a daily driver.
Happy to be here, thank you Chris for moderating here.
Guess the moral of the story is be prepared to open you wallet. haha. And you might not get the results you want with out spending even more.
Check your vacuum lines to the hubs. I went through 2 sets. They crack and then the "auto" setting on the hubs won't engage so you'll have to "lock" them manually.
I loved my 2000 and thought I'd keep it forever. Last couple years it just $1000-1500 dollared me to death. Had it long enough that I was starting to change or rebuild things I had done before. Not being a Debbie downer just my experience and you can see in my signature what I replaced it with. Engine is solid tho. Good luck.
Thanks for the trans advice. I've been looking everything over pretty well and haven't found any problems yet, though I do suspect that my vacuum line to one of the hubs is leaking based on the one wheel locking up when the hubs are in AUTO mode but both working as advertised in LOCK mode.
I bought the rig just before the weather started turning so I didn't get a chance to go underneath it with a fine tooth comb. I did give it a general inspection and everything looked good so I'm hoping it can make it through the winter with no issues then I can start working on things next year.
Right now I looking for a service manual set that doesn't break the bank and some sort of scanner setup.And I'm trying to figure out which gauges to get. I've read some things about going with a EGT and fuel pressure gauges and then displaying trans temp and boost through the scanner setup. Still learning. And at $200+ for the gauges you mentioned I want to make sure I'm getting everything right.
Thanks again for the info
Todd
I've got a 96 F250 7.3 that is pretty much stock engine wise. Had the tranny rebuilt and beefed up at 236,500 miles. It was a little tired, but still good. Since we had been hauling very heavy and overweight I decided to go ahead and have it refreshed and 'bullet proofed', although I don't believe anything is really bullet proof. After the rebuild, and at the recommendation of my transmission man, I installed a
Long Tru-Cool LPD Transmission Oil Cooler 4590 28,000 GVW. It does a much better job at keeping the transmission cool than the 10 line heavy duty Haynes we had on there. We pulled Willamette and Santiam passes rather regularly and in June of this year with our new 1062 Lance Camper on board, went up to Wallowa Lake and Hells Canyon - Buckhorn Springs Lookout as well as several other points of interest.
One load with the Camper on board and towing 6000 lbs. of boat with a 500 lb. tongue weight, and a couple of hundred pounds of fish, we went across the scales at 16,400.
Usually and most normally we are around 13,500 with the camper on board. I still have this pickup and use it regularly, but as of the end of July have gotten it some relief.
I've picked up a 2011 F350 dually with the 6.7 PSD in it to do the heavy hauling now. I figured after 244,000 my 96 7.3 deserved a bit of a break.
Again, welcome aboard.
Anyway, thank you again for the welcome!
Yes, P3 Orion, Flight Engineer, West Pac. R&R in Australia was fantastic and New Zealand was beyond fantastic!. Very good times. Pages in the bad times book have been burned.
I was Air Force myself. F16 and FB111 crew chief. Great job, lots of fun and I learned a lot from it. Currently working for a company in Bend the is aerospace related. Good work!
Thank you for your service!
Bwahahahahaha!
