water jacket cracks
Old Dec 3, 2019 | 09:56 PM
Nelson 2's Avatar
Nelson 2
water jacket cracks
I'll try and avoid restarting this thread from previous years. I have a pre 1977 351m/400 engine that I was going to use on a project car. Not so sure now because of the water jacket crack issues. The question is how far do I have to go "into" this currently running engine that has 150,000 miles on it in order to see the cracks, or can I check it in a different way such as a pressure test before I start turning any wrenches. Thanks to all
Old Dec 3, 2019 | 10:44 PM
85e150's Avatar
85e150
Seems like early blocks from Michigan are a potential problem. Since the leaks look to be in the valley, a pressure test would find them but you'd have to pull the manifold to see. (afaik based on the pictures)
https://www.tmeyerinc.com/tech/351m-400-identification/
https://www.projectbronco.com/Techni...the_rumors.htm
Short answer, full tear down and magnaflux to be safe.
Old Dec 4, 2019 | 09:23 AM
Nelson 2's Avatar
Nelson 2
Thanks, I was expecting that.
Old Dec 28, 2019 | 09:45 PM
Nelson 2's Avatar
Nelson 2
Engine date code
I want to check the date code before I remove this project engine, 351M-400. I know the code is on the rear of the engine next to the sending unit. Because I have to remove 30 years of grease and use a mirror to see can someone point out if the code is on the passenger side or the driver side of the block. Thanks
Old Dec 29, 2019 | 12:36 PM
alloro's Avatar
alloro
The only true way to test it is to strip it down to the block and magnaflux it.
julie 54
Jun 22, 2012 09:43 PM
joel79ford
Dec 23, 2011 08:59 PM
yamahead
Jul 9, 2009 12:10 PM
mcdev
General Automotive Discussion
Jun 28, 2004 01:08 PM
rfgre
Mar 21, 2001 11:17 AM
