Jumpy timing 3200+
Old Jan 1, 2020 | 07:33 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Jumpy timing 3200+
With the light on it, harmonic balancer is smooth as butter to 3200 then is ALL over the place, 10-15* each way jumping back and forth. Vacuum unhooked. Initial thought is chain, but 60k on it, did they use composite cam gears in 69? Same symptoms with two different distributors. Only other thing i can think is spark jump but the engine runs smoothly. Has msd 6al, isnt around 3200 where they drop to single spark?
Old Jan 1, 2020 | 08:10 PM
xlt4wd90's Avatar
xlt4wd90
Did you try running without the MSD?
Old Jan 1, 2020 | 08:44 PM
hairyboxnoogle
I want to say it did it before i put the msd on, and was jumpier in general, but dont quote me. No longer have the points dizzy to stick back in.
Old Jan 1, 2020 | 08:59 PM
hairyboxnoogle
Might have answered my question from a thread on another board.
tried or considered a different timing light? i`ve experienced the same problem but solved with another light.MSDs and some dial backs do not play well together. Consider the fact that MSD does not sell a dial back timing light, nor do they suggest the use of one.
Mine is in fact a digital with dial back feature, and not an expensive one at that. Guy is running a 6A having same problem i am, where its fine till ~3000 rpm and jumps around.
Old Jan 2, 2020 | 09:35 AM
beartracks's Avatar
beartracks
Fancy timing light will not work with an MSD box. they get confused.
Old Jan 2, 2020 | 12:11 PM
xlt4wd90's Avatar
xlt4wd90
It might be the timing lights start to detect the multiple sparks as contiguous streams at higher rpms. Just guessing.
kkkd
Aug 8, 2013 10:53 AM
nikwave
16
Aug 1, 2011 05:52 PM
Riderman
34
Jan 11, 2010 11:01 AM
jdlongmate
Nov 13, 2008 12:14 AM
Truckmano5
15
Jul 27, 2005 03:25 PM
