No high idle when cold
Old Dec 3, 2019 | 06:47 AM
cpobst's Avatar
cpobst
I have noticed lately that my truck does not idle up in the mornings. This morning is was 28 when I started it, I let it idle for around 5 minutes but it never idled up. It has done it in the past so I am wondering if this is a side affect of a change I made with Forscan? I am guessing this is the PCM that controls this so if nothing else I can start undoing things or reload the factory settings. Just curious if anyone else has experienced this?
Old Dec 3, 2019 | 09:06 AM
TeddyD's Avatar
TeddyD
From the owners manual:
“In cold weather below 32°F (0°C), the engine may slowly increase to a higher idle speed if you leave it idling in park (P). As the engine warms-up, the engine sound level decreases due to the activation of PCM-controlled sound reduction features.”
Maybe the truck temp sensor thought it was a couple degrees warmer than it was and didn’t engage the high idle. You were pretty close to the temp line. Another user from Michigan said his high idle wasn’t engaging either at 30F.
Old Dec 3, 2019 | 09:08 AM
cpobst's Avatar
cpobst
Thanks for the reply, what trips me up is I remember it idling up at warmer temps in the past. Maybe I'm over thinking things, which I do quite a bit.
Old Dec 3, 2019 | 09:15 AM
TeddyD's Avatar
TeddyD
I know mine idles up at 0*C but I don’t know if it idles you at 1*C though. I haven’t paid that much attention. Yesterday was 0 when I started the truck and it did idle up so that how I know it worked.
Old Dec 3, 2019 | 10:11 AM
TeddyD's Avatar
TeddyD
Just had to update. It’s -1*C here and I started the truck. Auto high idle did not engage but it did the other day at 0*C. Must be right on the borderline temp so I would worry if I were you OP.
Old Dec 3, 2019 | 10:30 AM
C12H24's Avatar
C12H24
You would have to know what the coolant temperature sensor is reading at start up. It's not a scientific instrument so it can be off a degree or two.
fordman19762003
Nov 3, 2019 11:39 AM
2000F250guy
Dec 14, 2011 07:45 AM
akorcovelos
Nov 3, 2010 10:30 AM
mblanken881
Feb 27, 2009 07:45 PM
Golflug
25
Feb 11, 2008 09:38 PM
