Radiator Repair
Old Nov 30, 2019 | 10:35 PM
SonofaFord's Avatar
SonofaFord
Radiator Repair
1978 F150, I6 300, with the little radiator.
Has anyone tried repairing a pinhole leak on a radiator? Suggestions on how to?
I have a good radiator shop nearby, but I'm trying to save some time and money by just doing it my self. I do have regular copper pipe solder and a torch.
Old Dec 1, 2019 | 07:37 AM
Tedster9's Avatar
Tedster9
Depends on where it is leaking at?
Old Dec 1, 2019 | 08:55 AM
john jamieson's Avatar
john jamieson
It's doable. I've done it on my old radiator until i replace it when I rebuild the motor. The tubes can be hard if the hole is from the walls becoming thin from age use. Too hot a torch and it will burn/enlarge the hole.
I went to the hardware store and got the lowest melting solder I could find. They have lead in them. Plumbing solder doesn't and melts at a higher temp. This isn't critical if repairing a crack in the tank but can help on the tubes.
john
Old Dec 1, 2019 | 11:39 AM
Olblack's Avatar
Olblack
If the leak is on a tube you can get to. With the radiator out clean the area where the tube inters the tank. Use some flux. Heat the tank area around were the tube goes in with the smallest tip you have with light heat. Pull the tube lightly with a needle nose pliers , a little jiggle to loosen. Sometimes the solder present will flow back into hole but be ready to add some. If in an inner radiator tube you may have to work your way in.
Sometimes the tube can be soldered shut or remove the other end from the tank probably easier. The loss of one tube should be ok. And a pretty solid fix.
Old Dec 1, 2019 | 01:29 PM
Mark8man's Avatar
Mark8man
Good reply Olblack. This is exactly how I have repaired many leakers back in the day either because I didn't have money for a re-core or had to get vehicle back on road so I could make to work. I recall having a rad with 6 or 7 tubes eliminated and it was fine.
Old Dec 2, 2019 | 09:16 AM
HoustonDave's Avatar
HoustonDave
it ain't pretty but I recall keeping a '70 Cutlass going for three years with a JBWelded patch.
Old Dec 2, 2019 | 09:30 AM
beartracks's Avatar
beartracks
Barr's Leak?
Old Dec 2, 2019 | 01:32 PM
SonofaFord's Avatar
SonofaFord
Alrighty folks, back with a fixed radiator.
So I was installing a new water pump since the old began to weep. It was a real pain because of the compressor bracket attached to one of the mounting bolts and was in the way for a direct install. During my fumbling the pump feel out of the hole and hit the radiator on one of the tubes about 1/4 up from the bottom causing the leak/hole. Taking all ya'lls advice and searching some Youtube, I went and got a Soldering Iron and some "Metal Work" solder and patched the tiny hole. Now it's full of coolant, run up to temp and no leak. Thank you all for the help! I looked up a new replacement, it would have been $330.00 plus shipping. I spent less than $40 on the iron and solder.
Old Dec 2, 2019 | 11:12 PM
Ozzie H.'s Avatar
Ozzie H.
Congratulations! $40 is far better than $330, plus you learned something. That's why I prefer the old brass & copper radiators. A "pinhole" can almost always be repaired if access is possible. Sometimes a bit of acid might be needed on the surface to assure cleanliness on an old radiator.
Old Dec 3, 2019 | 01:42 PM
SonofaFord's Avatar
SonofaFord
Yeah, luckily the hole was facing towards the engine. The "Metal Work" solder had an acid core. I also tired using a wire brush before doing any of the solder. WE shall see how it holds up!
Ron Pauly
Jul 16, 2018 09:33 AM
farmnaggie
16
Jul 13, 2016 10:09 AM
notthemaniusedtobe
Feb 6, 2015 05:41 PM
2003EXPY
Apr 11, 2013 04:15 PM
