Leaf Spring Overhaul
Old Mar 3, 2016 | 10:17 AM
padlikehel's Avatar
padlikehel
Hi all,
I'm back to pick y'alls brains on leafsprings....
On my '77 F250, I think its time to pull them out and give them a goin over.
It looks like someone added a leaf or two in the past, and that's my first question. In stock form, how many leaves are supposed to be in there?
And then from there, are there any tried and true methods for doing this?
My thinking is to take them out, clean them up, replace the bushings, put some good grease on the load bearing surfaces and then put them back together.
Are there any pitfalls that I'm not thinking about?
Thanks in advance.....
Old Mar 3, 2016 | 10:35 AM
Ancona's Avatar
Ancona
Originally Posted by padlikehel
Hi all,
I don't know how many leafs yours has stock, but I removed the ones on my '79 F-350 to do add-a-leafs and replace the bushings. The old bushings had to be pressed out, and the outer metal shield on the bushings separated and remained. I cut them with an air grinder length ways to provide a relief point, then split them with a chisel to remove. Then pressed in the new bushings.
Old Mar 3, 2016 | 11:41 AM
phlegm's Avatar
phlegm
A while back, I upgraded the leaf springs in my '75. I found that it was on a late '77-79 frame.
2009 F250 Rear Leaf Springs onto a 75 F250 -- OFCC.com
I made this chart using information from SD Springs webpage.
The problem is that '77 was a change over year and you could yave either the C7TE-5560-G springs with 6 leaves plus 3 overload. Or the D3TZ-5560-D with 4 leaves plus 1 overload. You would have to do some measuring to figure out which ones you have.
If you have the later springs 24/31.5" you could easily upgrade to 1999-2007 leaves 25/33.25 and get a little more carrying capacity and height. My local wrecking yard sold me the 2009 springs for $75/each.
Not so much a pitfall, but compare your time and cost of bushings vs 'new' springs. I think SD Springs even sells direct replacements for your truck for under $200 each. A little research now can save you some heartache later.
Old Mar 3, 2016 | 12:10 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
Hi all,
They came a few different ways from factory. You either have a 6 leaf, a 3/1 leaf spring or a 4/1 leaf spring. All had slightly different arches and different weight capacities.
You basically nailed it on the head. When it comes to putting them back together just make sure you are basically reversing the process of when you took them apart. When you are compressing the leafs a C clamp will be your best friend, don't rely solely on the center bolt to pull everything together, you don't want to strip it. Take a look at the tip inserts when they leafs are apart, it may be a good idea to change them out while you have the leaf spring apart.
Feel free to send me a message on the parts you need and I can hook you up with what you need.
Old Mar 3, 2016 | 12:46 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes removing the old bushings/installing new can be a PITA, a press works great. Do not forget the one in the shackle also.
If you are planning on trying to reuse the old u-bolts (not recommended) clean the threads VERY well, like with brake cleaner/WD-40 and a wire brush. The nuts can seize up due to being fine thread after a little dirt gets in there.
New u bolts is a good call. And yes put the old leaf pack in a vice before you remove the center pin, same for reassembly time. And yes use a couple of C clamps to start the compression, in case your vice is not big enough.
Insp the leaf spring edges right where they almost touch the ubolt, that is where they crack. And use a torque wrench when doing the ubolts, drive it and let things settle then retorque.
And then again like in 50, 100, 250 miles, they will work loose like crazy. Insp the hanger hole where the leaf spring bolts goes thru for being worn too.
Old Mar 6, 2016 | 01:42 PM
padlikehel's Avatar
padlikehel
Ok.... Got some pics today. Thanks for everybody's response.
This is what I'm dealing with. It looks like the original springs were 5 leaf with one on the bottom. But, like I said, it looks like somebody added 3-4 leaves before I bought the truck. As I'm looking at it, it looks like the top brackets that the U-bolts go through, aren't the right ones, or somebody put them in wrong....
So once again, any and all input is appreciated.
I think I know why they lifted the rear end. It looks like the drivers side dual exhaust pipe rubs on the driveshaft, when the suspension is at full bottom now. I can see where it would rub all the time if at stock height.... The more you dig, the more you find.....
Old Mar 6, 2016 | 01:43 PM
padlikehel's Avatar
padlikehel
More pictures
Old Mar 6, 2016 | 01:44 PM
padlikehel's Avatar
padlikehel
And some more....
Old Mar 6, 2016 | 01:46 PM
padlikehel's Avatar
padlikehel
Sorry for the weird orientation of some of the pics. I'm not very savvy when it comes to the uploading pictures thing.
Old Mar 6, 2016 | 10:27 PM
phlegm's Avatar
phlegm
No lift block.
Thats interesting. I thought every old Ford truck had them installed.
I attached a picture of my leaf spring and spring clamp plate as installed.
It looks like yours is upside down and 90degrees off.
Do you have any better picture of it?
I'm wondering if on the added in leaves, should you bevel the ends while you have it apart? Also I wonder if you should add another set of spring clamps?
Old Mar 7, 2016 | 09:15 AM
padlikehel's Avatar
padlikehel
That's what I thought. But now that I see yours, it looks like they not only put them on wrong, but also bent the ears of the brackets in order to make them fit....
When all they had to do is turn them. Dumb, dumb, dumb....
Does anybody know if the brackets are available? LMC truck calls them spring seats, but they only show them available for 1/2 ton.
I'm thinking some wire wheel,grease, new u-bolts and spring seats and I'm back in business....
Old Mar 7, 2016 | 09:43 AM
hivoltj's Avatar
hivoltj
That is a hot mess
Old Mar 7, 2016 | 03:02 PM
41505379's Avatar
41505379
If the springs are serving you well just spray them with WD40 to make them and you feel better and move on. Patrick
Old Mar 7, 2016 | 03:29 PM
padlikehel's Avatar
padlikehel
I went back over the thread and saw, I never explained what the problem is.
It's two things actually. First, I think the springs are binding. Whenever I come to a hard stop, or take a fast corner you can hear them pop.
The second problem has to do with ride height. I am going to put a receiver hitch on the truck, in order to haul my old tractors around with it.
Well.... The truck is jacked up so high in the rear, it makes the geometry for the hitch look really weird. My trailer tongue height is 16". The bumper height now, is 24" So even after I install the receiver hitch, I would have to use a 6" drop tongue to make it work out.
And then I'm riding with the geometry of the truck's suspension all wrong. Not something I want to do, pulling a 2500-3700 lb tractor....
So... This is actually a two part job. I'm changing the front springs, and then there was the rears which I needed advice on.
And you guys have come through! Thanks!
Old Mar 7, 2016 | 04:00 PM
phlegm's Avatar
phlegm
This may not be the answer you are looking for, but...
you may want to consider taking some of the leaf springs from the bottom and moving them to the top, then adding a second set of overload spring brackets.
As long as you have a single through bolt to hold it all together, it should look just like my stock 2005 F250 Camper Package springs (which are similar to the picture I attached)
You will have to figure out what to use for leaf spring stops at both front and rear.
Its just an idea, it would lower your ride, soften your ride, and still maintain the same payload capacity.
