Faulty ICP?
Old Nov 27, 2019 | 09:01 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Faulty ICP?
Truck in question is my 2000 7.3 with 143k on the clock. Over the last six months or so I've noticed the trucks idle randomly surge at times. I can hear it surge and also notice the tach moving ever so slightly. It will do it when in park or stopped at a light. Doesn't matter if the engine is hot or cold. My ICP sensor and pigtail are void of any oil. The other day at work I was letting it idle in the parking lot and it started surging. Not surging violently but enough that I could hear the change. I unplugged the ICP and there was a short hiccup in the idle and then it smoothed out and idled better than is has in a while. Is this the sign of an ICP sensor on its way out?
I do monitor the ICP with my edge cts and it always seems to be within the right parameters.
Old Nov 28, 2019 | 08:24 AM
FordTruckNoob's Avatar
FordTruckNoob
What are the ICP readings? Are they staying fairly constant? What is IPR DC while this surging is going on?
Old Nov 28, 2019 | 09:33 AM
F0rdc0wb0y's Avatar
F0rdc0wb0y
on a hot engine at idle the ICP is at 450-480 psi and the IPR is at 10.5-11%. Of course these values change when the engine is colder. Everything seems to stay fairly consistent. Might have to just keep an eye on it as time progresses.
bc18
Aug 11, 2017 09:28 AM
Fordenthusiasts
May 10, 2016 10:28 PM
six6six
Aug 22, 2014 01:04 AM
tennesseecoalroller0
30
Mar 19, 2012 08:32 PM
lakewood
Sep 10, 2011 07:13 PM
