2019 oil pan
Old Nov 27, 2019 | 04:22 PM
hdman6's Avatar
hdman6
Question 2019 oil pan
I had a 2002 7.3 with the dreaded oil pan leak issue. I nursed it along until it was sold this week. So I now have a 2019 F250 6.7 Crew Cab. Looking under i dont see any cross member under the pan which is a nice feature. I was wondering what the material is made of. Did they upgrade to aluminum pans? If it is steel again do i need to spray it so I don't end up rusting it out over time like the last one. I would like to pre empt the start so to speak. thanks
Old Nov 27, 2019 | 07:52 PM
dirthawg's Avatar
dirthawg
There is an upper and a lower oil pan. The upper portion is aluminum the lower pan which houses the drain plug is steel (unless something has changed since the 2016 models). I personally wouldn't bother spraying it with anything to prevent rusting because it's an easy and cheap item to replace if it does rust through.
https://parts.autonationfordwhitebea...-pan-bc3z6695b
Old Nov 28, 2019 | 08:51 AM
senix's Avatar
senix
What I would do is paint it and other parts to prevent rusting if unpainted.
Then I would (and do) spray fluid film on those steel parts as a rust/salt corrosion inhibitor.
Ringwood1
Dec 3, 2010 02:52 PM
kupiec20
May 18, 2008 10:10 PM
davidw221
Jun 21, 2007 04:27 AM
worknon10s
Apr 7, 2007 03:29 PM
