Rusted oil Pan
Old Jun 20, 2007 | 04:35 PM
davidw221's Avatar
davidw221
Cool Rusted oil Pan
I was under my truck today, spraying undercoating, when I noticed the oil pan was rusting, I have heard the motor needs to be pulled to replace the oil pan, that thought sickens me, but is there a cheaper way? can the pan have a spot weld with a patch on it?
Old Jun 20, 2007 | 04:46 PM
nedaclu's Avatar
nedaclu
i'm from the oilfields, this is what we would do if the pan wasn't rusted all the way through.
sand down rust spot paint with primer and spray undercoating on pan.
we even did this on cat dozers in mud pits made them last alot longer.
Old Jun 20, 2007 | 07:36 PM
Kwikkordead's Avatar
Kwikkordead
If it is dripping you can weld it up if you are very careful. Treat it like you are welding on a barrel, using a vacuum cleaner attached to the filler neck and the drain plug removed to give it a LOT of air exchange.
If it's really bad as a last resort it would be worth the price of a new oil pan to just cut the bottom off of both of them and weld up the new one to the old one.
If that doesn't work, (I don't see why not) then, yeah, pull the engine.
Old Jun 20, 2007 | 08:01 PM
Uzumati's Avatar
Uzumati
If it is not to bad sand it down and coat it with Por-15
http://www.por15.com/
Old Jun 20, 2007 | 10:04 PM
Ed in Maine's Avatar
Ed in Maine
I have the same issue, very bad rusting all over corners of the pan. I bought one of those convert rust to primer conversion type kits that are supposed to help. Have not put it on yet though....
Old Jun 21, 2007 | 04:27 AM
slack's Avatar
slack
Por-15 works great. Did my oil pan last summer,hard as a rock.
