Sponsored by: Real Truck
Shifting issues?
Old Nov 27, 2019 | 02:36 PM
Ethan Engle's Avatar
Ethan Engle
Shifting issues?
Alright so I have a 1999 F250 Super Duty. I’m having issues with it changing gears. I just swapped the neutral safety switch, and it has helped slightly. I can start the truck in park but it won’t shift to any other gears. If I start it in neutral, I can drop it into other gears, but the moment I put it in park, it won’t shift out of it. I’ve read about the shift tube, and mines a little loose, but could that be it? The torx bolts are all tight, top and bottom side.
Old Nov 27, 2019 | 06:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Do your brake lights work? Usually, this problem is a bad brake light switch. The TRS (Transmission Range Switch, the thing you called the neutral safety switch) has nothing to do with getting it out of park.
Old Nov 27, 2019 | 07:14 PM
Ethan Engle
Yes they work . A brake light switch would keep my truck from shifting out of park into other gears?
Old Nov 27, 2019 | 08:02 PM
Mark Kovalsky
There is a solenoid that holds the shifter in park unless the brake lights are on. If the brake lights work then it may be a bad solenoid in the steering column.
Old Nov 27, 2019 | 08:23 PM
Ethan Engle
I mean unless I have really bad luck, I just swapped steering columns because of this issue and another which I fixed.
Old Nov 28, 2019 | 08:47 AM
the_old_ranger's Avatar
the_old_ranger
Is the shift interlock releasing? Also the shift cable might be wore out. Check your cable adjustment.
Old Nov 28, 2019 | 09:57 AM
Ethan Engle
how would I tell? Shift cable is what goes down to the tranny right?
Old Nov 28, 2019 | 12:26 PM
the_old_ranger
Yes it is. I would unhook it from the trans and see if it moves freely . Also see how it lines up with the trans where it connects with shifter and trans while in neutral. Also check the neutral safety at same time.
Old Nov 28, 2019 | 02:54 PM
Mark Kovalsky
None of that could cause it to not come out of park.
Old Nov 28, 2019 | 03:38 PM
the_old_ranger
You are absolutely right Mark! I was just thinking of if he is out of adjustment It's gotta be the interlock solenoid not releasing I mean it is the only logical answer. I took my interlock off my truck,. not sure if it was a good idea or not?
Old Nov 30, 2019 | 01:02 PM
Ethan Engle
well, I’ve replaced the shift interlock solenoid and it still won’t come out of park. I’m not sure where to go from here gents.
Old Nov 30, 2019 | 01:47 PM
Mark Kovalsky
Does the shift solenoid get powered? Does the power go away when you step on the brake pedal?
Old Nov 30, 2019 | 06:00 PM
Ethan Engle
fixed it. The shift tube was bad
Old Nov 30, 2019 | 07:10 PM
the_old_ranger
That's great Ethan!
F350Man79
Oct 10, 2022 10:12 AM
Bryan L.
Oct 5, 2014 01:56 PM
littlewad
1983 - 2012 Ranger & B-Series
Jun 11, 2012 12:31 PM
ErnieX
Escape & Escape Hybrid
Jun 13, 2008 07:50 PM
78150
Dec 22, 2007 03:12 PM
