gear shift from park
Old Jun 9, 2012 | 11:27 AM
littlewad's Avatar
littlewad
On my 1996 Ranger, when I crank up the motor the truck will not shift out of PARK. With truck off, I can turn switch to on position, then shift to neutral to start motor then change gears. How can this be fixed.
Old Jun 9, 2012 | 12:42 PM
87 XLT's Avatar
87 XLT
Are your brake lights working?
Old Jun 9, 2012 | 03:42 PM
littlewad's Avatar
littlewad
I just checked. No the brake lights are not working.
Old Jun 10, 2012 | 12:28 AM
87 XLT's Avatar
87 XLT
The brakelights & the shift lock solenoid are powered from the brake light switch. Check the brake light fuse, if it's OK the most likely problem is a bad brake light switch.
Old Jun 11, 2012 | 09:27 AM
littlewad's Avatar
littlewad
Thanks, Your question led us to check the fuse and fix the problem.
Old Jun 11, 2012 | 12:31 PM
87 XLT's Avatar
87 XLT
And thanks for the update, glad you found the problem.
F350Man79
Oct 10, 2022 10:12 AM
Bryan L.
Oct 5, 2014 01:56 PM
Inkme
Dec 18, 2012 05:51 AM
66BlackCat
Aerostar
Oct 3, 2010 04:38 PM
Rexpedition97
Jun 12, 2007 09:02 PM
