Unknown connector
Old Nov 26, 2019 | 08:42 PM
Carrot66's Avatar
Carrot66
Unknown connector
1978 F150 Custom 4x4
351M
I am doing some work today and noticed this connector under the hood right on to of the big A/C box. It looks like a green wire and a white wire going in and a single blue wire coming out. There is 12V on the blue wire when the key is "on"
Currently the blue wire has been cut and was taped off.
Anyone know what this is used for?
Thank you
Carrot66
Old Nov 27, 2019 | 12:04 AM
meangreen92's Avatar
meangreen92
I think it's for the electric choke assist - at least the white wire. If I'm correct, the white wire should have continuity to one of the terminals on the alternator. And... I forget which terminal. Pretty sure it's F (for Field) or S (for Stator). Which ever terminal it is, it supplies unrectified AC voltage to the choke assist, rather than the DC voltage which powers everything else on the truck.
Does your rig still have the original carburetor? OEM Ford carbs use the AC voltage, while pretty much all other carbs use DC voltage for the choke.
Old Nov 27, 2019 | 11:12 AM
CelticOne's Avatar
CelticOne
Regular User
Origininally it would have been connected to a solenoid on the drivers side of the carb (#4 below). As I understand it this was primarily for the AC system. It sometimes gets repurposed to a choke that has been converted to electric (#2).
Old Nov 27, 2019 | 05:06 PM
Carrot66's Avatar
Carrot66
Thank you.....You pointed me in the right direction.
Happy Turkey Day!!
Old Nov 27, 2019 | 07:52 PM
meangreen92
Happy Turkey Day!!
Right back atcha brother!
Old Nov 27, 2019 | 08:02 PM
marksman76's Avatar
marksman76
After reading others answers, I believe those were connected to the idle dash pot, that was activated when you switched on AC to increase the idle speed
chris989
Nov 18, 2016 10:30 PM
ktm4012
Oct 12, 2016 10:48 AM
Steven Gatley Sr
Electrical Systems/Wiring
Apr 11, 2016 07:29 PM
farmnaggie
May 27, 2006 02:44 AM
rshissler
Apr 23, 2005 05:51 PM
