Starts, dies immediately
Old Nov 26, 2019 | 05:58 PM
Oracertified's Avatar
Oracertified
2006 F-350 6.0-liter diesel. I have a pretty often intermittent problem. The engine spins and dies immediately. FICM is 48.5 volts always. I paid someone $802 to replace the fuel pump. It still does the same thing. I am reading that the Fuse Block under the dash may be the problem.
Anyone know what wire I need to tap into to see if the pump is getting power when it fails?
Thanks. I do like the truck.
Old Nov 26, 2019 | 06:50 PM
AL`'s Avatar
AL`
Have you used a scanner to check for DTCs?
Old Nov 26, 2019 | 06:58 PM
bismic's Avatar
bismic
+1 for above question!!
Do not guess - it gets expensive.
That said, several things are known for shutting down the engine - electrical problems with ICP, IPR, EBP, and even the FICM. You can have a bad FICM even w/ good FICM MPower readings.
Old Nov 27, 2019 | 06:15 AM
Oracertified
Forgot to mention the codes
The code that keeps coming back is P0231. Low fuel pressure.
The diagrams that I found show that I may be able to check the voltage at the inertia switch...?
Old Nov 27, 2019 | 06:56 AM
TooManyToys.'s Avatar
TooManyToys.
Interia switch or HFCM.
Whoever led you directly to a fuel issue and an $800 expense doesn't understand this motor.
The fuse relay under the dash is a 2003-2004 problem. The 2006 has the fuel relay and fuse under the hood as well as a separate fuse under the dash going by Rusty's image, but check your manual under fuses.
Old Nov 27, 2019 | 10:41 AM
SmackDaddy's Avatar
SmackDaddy
Turn the key and listen for the fuel pump running, it’s right under the frame by the diver door
Old Nov 27, 2019 | 10:55 PM
IHateCommieCars's Avatar
IHateCommieCars
IMHO, that's way too much to pay for a new pump. Even paying dealer prices for the pump, that's still $400 labor for a job that takes less than 2 hours. Walmart has Motorcraft pumps for $212.
Old Nov 27, 2019 | 11:36 PM
SmackDaddy's Avatar
SmackDaddy
$802 for a fuel pump swap? I’m in the wrong business!
DPDISXR4Ti
1983 - 2012 Ranger & B-Series
15
Jul 17, 2019 11:56 AM
Incom_98
Apr 14, 2013 11:36 PM
larrylass
Oct 18, 2010 08:51 PM
BrookFerrell
Mar 2, 2010 06:07 PM
rlynch131
Aug 26, 2008 07:27 PM
