Dash panel removal
Old Nov 25, 2019 | 07:23 PM
whisler's Avatar
whisler
Dash panel removal
On my 1989 F250 Lariat XLT, I would like to remove the dash panel section that contains the headlight switch, wiper switch and tank switch. How is this done without breaking the plastic panel ( which I am good at}.
Old Nov 26, 2019 | 03:11 AM
Exwhyze's Avatar
Exwhyze
I used a flathead screwdriver the first time, now I can yank it off by hand. Be gentle, that piece is in there pretty good. The hardest part for me was getting the washer/wiper **** and headlight switch ***** off.
Old Nov 26, 2019 | 08:11 AM
Broncor's Avatar
Broncor
I bought one of those door panel removal tools, seem to use it allot.
pull light and wiper switch off, don't lose little clips.
Use tool to pop corner of panel and now you can pop the rest off.
All other panels have screws as well as being clipped.
I set up a socket on my small cordless drill for removing screws, goes quick.
Old Nov 26, 2019 | 11:37 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What clips?
To remove the *****, put a pick or pocket screwdriver in the slot behind the **** and then pull toward you to relieve the tension on the retaining spring. The **** will come right off.
Old Nov 26, 2019 | 10:17 PM
Broncor's Avatar
Broncor
My bad, typing too early in am .
I meant clips on back of ***** not switch.
Old Nov 27, 2019 | 03:01 AM
My4Fordtrucks
That’s what I figured you meant. Don’t just grab the **** and pull. You’re doing wrong. See my previous post on how to remove the *****
Old Nov 27, 2019 | 07:43 AM
Exwhyze's Avatar
Exwhyze
I used a hooked pick on mine. They've been removed numerous times now and a small screwdriver won't release the tension on the clip enough to actually pull the **** off. Good luck! Use your phone camera to see what's going on in there if you have to. I sure did the first time!
Old Nov 27, 2019 | 07:37 PM
whisler's Avatar
whisler
Thanks to all.
DomB
Jan 16, 2014 04:37 PM
a1awind
Sep 18, 2010 08:18 AM
1joshie1
Aug 19, 2010 10:39 PM
bbdano
Dec 22, 2007 12:21 AM
Daryldb
Jun 21, 1999 08:50 AM
