headlight switch replacement
Old Jun 18, 1999 | 10:44 PM
Daryldb's Avatar
Daryldb
Sorry - first time user. My post should have included that it's a fancy '88 F350.
Old Jun 20, 1999 | 11:36 AM
car 36
Guest
Posts: n/a
I've got an '89... same dash setup.
Turn the **** until you see a small slot near the back.
Use a hook tool (kinda like a pointed punch that's bend on a 90 degree angle) to push the small metal tab back towards you. You kinda have to push in on the **** at the same time until you feel it release, then pull out. Once you've removed it you'll see what held it on.
Then you have to do the same with the wiper ****.
The panel just pops in. Gently push a screw driver under the panel and twist. The panel will pop out. You'll see the switch and the screws that hold it in.
The panel and ***** are old plastic pieces. If you mess them up, go to any junk yard and buy a couple for $5.
Old Jun 21, 1999 | 08:50 AM
slik's Avatar
slik
