02 F350 headlight help!!
Old Nov 25, 2019 | 06:39 AM
Devk22's Avatar
Devk22
4wd Low
Installed new h13 led headlight bulbs, and 9005 led fog light bulbs. When my switch is pushed in (fog lights off), high beams and low beams work normal when using lever on steering column. When switch is pulled out (fog lights on), fog lights will stay off when lever is forward and high beams are on which is normal.., but when I pull lever back to low beam position, the fog lights come on but the high beams stay lit and the high beam indicator on cluster goes out. This one has me stumped. Any ideas? Anyone have same issue?
Old Nov 25, 2019 | 08:40 AM
Colorado350's Avatar
Colorado350
Welcome to FTE.
It’s because you used bulbs instead of a LED housing w bulb which has resistors built in to it that prevents current flowing to the bulb. Typically companies will provide some sort of can bus or resistor block that plugs in the truck sockets then the bulb plugs into that, these eliminates what you have going on. You could contact the company and see what they say, return and find a company that provides the resistor block or install something like Truck-lites that have everything built into them.
Here’s what I used and did:
https://www.ford-trucks.com/forums/1...tes-led-s.html
Old Nov 25, 2019 | 09:53 AM
Devk22's Avatar
Devk22
4wd Low
Originally Posted by Colorado350
Welcome to FTE.
So you’re saying I need some resistors. On what bulbs would I connect the resistors to? The h13 high/lows, or the 9005 fogs?
Old Nov 25, 2019 | 10:29 AM
Colorado350
Typically they go on the bulbs that are staying on...but I don’t know where you’d start or what size. I don’t have time right now but I can find you the bulbs that I use for my Subaru and that company actually provided the plug-and-play system.
WW26Red
2015 + Expedition & Navigator
Apr 16, 2020 07:34 PM
Gilleyman
Nov 17, 2015 06:51 AM
ACFX4
1997 - 2003 F150
Sep 9, 2012 06:54 AM
bri687
Electrical Systems/Wiring
Nov 8, 2006 10:11 PM
4X4 IN REFUGIO
Oct 11, 2005 12:31 PM
