Rear end tag
Old Nov 24, 2019 | 12:54 PM
azgunner's Avatar
azgunner
Rear end tag
I am trying to figure out what kind of rear end was put on my truck. I have a 1984 Ford F-250 extended cab utility truck, with a 351W C-6 tans. I was told it was a 1ton rear end but I can not make heads or tales of the tag that is on the rear end. A pic is included so any help would be great. I know its rusted a bit but thats the best I can do, I didnt want to loose any thing off it.
Old Nov 24, 2019 | 01:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the tag pic had been posted horizontally, I might have been able to read it.
As it is, there is an AXLE code stamped on this ID tag, but it's too faint to make out. Post what it is.
AXLE code printed on the Certification Label, glued to the left door face below the latch. Post what the code is.
1984 F250 could have a Ford 8.8" integral, Dana 60, Dana 61-1, Dana 70. 1980/84 F350 would only have a Dana 70.
Old Nov 24, 2019 | 01:35 PM
azgunner's Avatar
azgunner
is this better, from what I can read
top line 4 10 (upside down triangle)E4T (cant read looks like AD)
Bottom line 6 5197 2 ( cant read but looks like ES)
Old Nov 24, 2019 | 02:04 PM
NumberDummy
Top line 4 10 (upside down triangle) E4TA-ADA // Bottom line 605197-2
Ford: E4TA-ADA ~ Dana: 605197-2 = Dana 61-1 Rear Axle / 4.10-1 / Limited Slip / 6,250 lbs. Axle Capacity.
1984/85 F250.
Old Nov 24, 2019 | 02:12 PM
azgunner's Avatar
azgunner
Now all I need to do is find what speedo gear I need, to make the spedo work normally or I should say read the proper MPH.
Old Nov 24, 2019 | 02:29 PM
NumberDummy
Now all I need to do is find what speedo gear I need, to make the speedo work normally or I should say read the proper MPH.
2WD or 4WD?
matthewq4b's Avatar
matthewq4b
The formula for caluculating the driven gear number of teeth on the speedo cable is as such
# DRIVE TEETH x AXLE RATIO x TIRE REV. PER MI.
_____________________________________________ = # DRIVEN TEETH
1001
To calculate tire revs per mile
20168
_______________________________ = REVIOLUTIONS PER MILE
TIRE DIAMETER (in inches)
So lets say you had a tire diameter of 28.89" and 7 drive teeth on the trans drive gear.
So 20168 / 28.89= 698.096 And round to 698 tire Revs per mile.
So knowing that we can use the other formula
7 x 4.10 x 698 / 1001 = 20.012 and to round it to 20. So you need a driven gear with 20 teeth.
Old Nov 24, 2019 | 04:30 PM
NumberDummy
Parts catalog lists: C7SZ-17271-B .. 18T Speedometer DRIVEN gear with C6, 4.10 ratio with 2WD
There's no speedometer DRIVE gear, as it's made as part of the C6's output shaft.
Old Nov 25, 2019 | 02:12 AM
matthewq4b's Avatar
matthewq4b
The drive gear is just integral with the shaft. Part of the shaft or not there is still a drive gear. Can't turn the speedo gear without a drive gear.
Old Nov 25, 2019 | 11:39 AM
NumberDummy
Yes there is a DRIVE gear, but since it's made as part of the output shaft, it cannot be replaced.
Old Dec 3, 2019 | 09:59 AM
Odisvan's Avatar
Odisvan
If you need to change your gear to get your speedo correct, you pull driveshaft/tailshaft housing, then remove a little funky metal clip that is hard to replace which holds the plastic gear on your tailshaft. At least that's on a turbo 350, I haven't changed speedo gear in a C-6 before. the plastic gears in various colors (ratio) aren't that hard to find, but that little clip that holds it IS, be VERY careful with that clip. I lost mine and had to go beg several transmission shops before one finally sold me one.
Old Dec 3, 2019 | 10:09 AM
Odisvan's Avatar
Odisvan
Sorry, didn't read good before I posted, are you saying C-6 doesn't have removable plastic colored speedo gear on tailshaft of automatic?
Old Dec 3, 2019 | 08:21 PM
NumberDummy
Originally Posted by Odisvan
Sorry, didn't read good before I posted, are you saying C-6 does not have removable DRIVE speedo gear on tailshaft of automatic?
C6 has a nylon speedometer DRIVEN gear at the end of the cable, but the C6 speedometer DRIVE gear is made as part of the output shaft (7060 in pic).
Old Dec 4, 2019 | 08:10 AM
Odisvan's Avatar
Odisvan
Thank you Bill, my bad. GM uses different nylon gears on the tailshaft held on by hardened metal half moon spring clip.
jimmy19892014
General Automotive Discussion
Oct 19, 2019 10:30 PM
slowsure
Oct 30, 2018 04:29 PM
t1956bird
Aug 7, 2013 01:12 PM
tribalzero
Jul 18, 2010 03:58 AM
50t16t
Dec 4, 2009 09:22 PM
