Help Needed to ID Parts
There are two thick felt like panels on the back of the cab between the the cab and the bed of these trucks. (I assume it is to reduce the vibration in this area) One of mine is falling down. They are not the air vents but located above the air vents and somewhat L shaped.
2019 F150 Super Crew Cab, build in June 2019, 5.0 engine 5.5 bed.
Okay, I found an article that mentions it.
https://media.ford.com/content/fordm...amic-drag.html
edited to add:
Robbgt, you could also be correct. There is another piece of trim that goes across the gap at the bottom of the bed where it meets the cab. Either or both of these items could help improve aerodynamics, reduce road noise, or help keep the bed from hitting the cab during assembly. Maybe both items do all three things at the same time, rather than serving a single purpose.
- Cargo box is narrower than the cab, with no reduction in box volume, which enhances airflow, while a trim piece prevents air from getting trapped between cab and box
edited to add:
paredneck33
12-08-2014 08:58 PM
gansz4
06-19-2007 12:42 AM
