driveshaft swap?
Old Jun 18, 2007 | 09:24 PM
gansz4's Avatar
gansz4
driveshaft swap?
i was just wanting to know if a two piece drive shaft out of a 1994 f150 xtended cab short bed was the same specs as the 1994 f150 flare side? i have a friend who is in bad need!
Old Jun 19, 2007 | 12:19 AM
dmanlyr's Avatar
dmanlyr
Well this is the 80-86 forum, so I may be wrong on your truck as it is newer, but if you are swaping from a ext cab shortbed to a reg cab ? (you did not make note of the cab type on the flareside) short bed the wheelbases are differet, at least in the case of the 80-86 model year trucks -
116.8" reg cab short bed (flare or styleside)
133" reg cab longbox
138.5" ext cab short box
155" ext cab long box
168.4" 4door cab long box
I hope this helps, David
Old Jun 19, 2007 | 12:42 AM
jdgreen72's Avatar
jdgreen72
measure it with a tape.
