PCV Valve question
Old Nov 23, 2019 | 05:59 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
PCV Valve question
I just changed the pcv valve (after I finally found it) and can someone explain why it has a coolant loop around it ? Just curious ….
Old Nov 23, 2019 | 06:54 PM
85e150's Avatar
85e150
What year and engine? I found a video on a 2001 4.0 SOHC, which shows it off the driver side of the engine seemingly under the ignition coils. As such, I can only guess that the coolant line is actually to heat it up so it doesn't freeze. Lots of what comes through there is water after all.
Old Nov 24, 2019 | 05:42 AM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
DOH !!!! I forgot my signature doesn't show the Ranger . It's a '03 4.0l XLT 4x4 . What you said makes sense . Don't think we need it down here , but you never know . And yes it is on driver side rear on valve cover . What a pia to get the elbow off and unscrew the valve . Thanks for your help .
Old Jan 25, 2020 | 02:07 PM
Georgeandkira's Avatar
Georgeandkira
Heated PCV
New-to-me truck ('05 FX4 Off Road) had a thoughtful but not completely efficient P.O.
The PCV was original. I bought one from AutoZone and rolled it into the existing heater pipe.
I was thinking about wrapping the entire thing in insulation but I don't want it to melt.
As it is, I don't want the AZ product to melt either.
And YES, getting the elbow off the PCV itself is the hardest part of the job. The 1/3 turn to unscrew it wasn't difficult at all.
My original one was clogged and barely rattled with severe shaking.
See you in 20,000 mi. or is it 30,000 mi.?
Redranger03
15
Jun 27, 2024 03:47 PM
afreemanmd
Nov 23, 2009 12:00 PM
randy6800
Mar 13, 2008 07:06 PM
LEFTBEHIND
3.8 & 4.2L V6
Jan 12, 2008 05:26 PM
Bud ward
Mar 12, 2004 10:28 PM
