I,ve looked on the passenger side behind the coil pack and found what I thought was the pcv valve. When I got it out I found it was a plastic elbow with nothing inside. Is this motor suppost to have a pcv valve?
The 4.2 is different and it does have a pcv valve that according to my illustrations should be located in the valve cover, the part number 1L3Z-6A666-AA. I hope this information is helpful.
it pcv is right infront of the intake and behine the throdle body. it has two lil lines for coolant and on big line for vac that goes to the intake. it is a heated pcv cost like 45 bucks only at a dealership.
