Sponsored by: Real Truck
2003 gear shift
Old Nov 22, 2019 | 09:25 PM
Vinford's Avatar
Vinford
2003 gear shift
2003 F350 4x4 diesel
pulled into reverse and something let go?
Gearshift just flopping around, had to crawl under and shift into drive to get home from the bush.
Nobody knows what makes this tick?
53 reads?
Old Nov 23, 2019 | 09:28 AM
bwguardian's Avatar
bwguardian
Look up under the dash at the steering column. There is a screw that typically works loose making the shift sequence sloppy. If it came out...hopefully if so the screw would be on the floor board...then I can see your scenario. If not, then a cable probably broke.
Old Nov 23, 2019 | 09:05 PM
Vinford's Avatar
Vinford
Figured out
Well figured out whats wring but nor sure on the fix?
took plastic piece off top of steering column .
theres a grey potmetal piece that runs from gearshift lever diwn the steering column.
i can see its broken in half?
Andy_F100
Feb 25, 2017 02:59 PM
pukey
Dec 31, 2010 04:21 PM
SNEWTON
Oct 8, 2008 04:26 PM
77shorty
May 21, 2005 09:54 AM
bigmike09
Sep 26, 2003 01:11 PM
