sct tuner
Old Nov 22, 2019 | 09:55 AM
beercake's Avatar
beercake
sct tuner
Which SCT tuner is the best for monitoring truck? Truck is used for commuting and occasional towing. Engine has 20,0000 on it from full rebuild. ARP studs , KKD o-ringed heads,stock om injectors,BPD 58 v FICM, blue spring kit and adjustable fuel return regulator.
2006 motor in 2004 truck
Old Nov 23, 2019 | 07:39 AM
SmackDaddy's Avatar
SmackDaddy
If you don’t plan on running tunes I’d skip the SCT tuner and use Forscan or TorquePro on your phone or tablet. I bought a Samsung Galaxy 8 tablet that stays in the truck and is using a bluetooth dongle (BAFX Products Bluetooth Diagnostic OBDII Reader) and TorquePro.
Coolant Temp (ELC) Delta Oil Temp Battery Voltage RPM Boost VGT FICM Voltage IPR %open ICP Voltage HPOP (ICP) Transmission Temperature
Old Nov 23, 2019 | 08:00 AM
beercake's Avatar
beercake
Thanks for the feed back. That is a good option
Old Nov 23, 2019 | 09:50 AM
F350 1990's Avatar
F350 1990
Why waste good money on an obscenely overpriced SCT?
Go with Torque Pro -- $4.95
Old Nov 23, 2019 | 10:02 AM
F350 1990's Avatar
F350 1990
The current (and fastest) version of Bluetooth only runs around 2Mbps.............if you can find a decent WIFI 802.11 adapter you'll be running nominally around 162.5Mbps and you'll notice a dramatic difference in performance on any number of WIFI-enabled scan tools.................
Old Nov 24, 2019 | 12:17 AM
87crewdually's Avatar
87crewdually
I agree with Smackdaddy but I side more with Forscan over Torque. And here are baseline numbers from my 05 at hot idle via Forscan to give you an idea. The app was about $5 for android and the elm327 bluetooth was about $15 on Amazon.
You wouldn't normally need to monitor all of these while driving but for diag they are handy.
Devdye
Jun 7, 2016 12:47 PM
Tlberry
Oct 14, 2015 09:49 PM
Splash67
Jan 19, 2014 04:02 AM
Monty Simmons
Sep 27, 2013 08:48 AM
fordf3502007
Apr 6, 2008 05:30 PM
