Belt Help!
Old Nov 22, 2019 | 04:02 PM
69cj's Avatar
69cj
Originally Posted by SmackDaddy
I was just reading about that and lots of other shops don’t recommend o-rings and Fel-Pro
It's been a few years back but seems that I read, unless your pumping big power, racing, o-ringed heads are not the way to go with the 6.0. Wish I had saved the article for you.
Old Nov 22, 2019 | 04:06 PM
SmackDaddy's Avatar
SmackDaddy
It doesn’t hurt to have them, same with head studs versus bolts.
I have 175/30s, Powermax quite a few engine upgrades and I really don’t feel like dealing with blown head gaskets again so studs and o-rings it is.
Old Nov 22, 2019 | 05:15 PM
RoberDen's Avatar
RoberDen
I just pulled my 6.0 yesterday and took a photo of the belt route before I removed it.
Alternator is last. Look at SmackDaady's photo. The 1/2" breaker bar fits into the tensioner pulley arm on the right and then rotate clockwise to remove presurre from the tensioner. There is a spring loaded clip below the leftmost pulley of the tensioner that holds the rotated tensioner in place,Then put the belt on alternator and ease back the breaker bar, the clip will spring back in place and you are done.
Old Nov 22, 2019 | 05:18 PM
RoberDen's Avatar
RoberDen
Here is where the holding clip is located.
Old Nov 22, 2019 | 11:08 PM
Texas Bob's Avatar
Texas Bob
I've never had any luck in getting a pry bar/tool into the 1/2" hole on the tensioner. I also have not had any luck pulling the belt so I can trip the lever on the tensioner. I have had multiple successes in using two large philips head screwdrivers placed in two holes in the base of the alternator with the belt loosely on and then putting the ends in the mounting and rotating the alternator up. Somewhere on this site is a better description and I believe a photo of how to do it.
Old Nov 23, 2019 | 12:23 AM
IHateCommieCars's Avatar
IHateCommieCars
I've done it that way too, but using a breaker bar is easier, IMHO. Not sure how you could get a pry bar in there though. If you still have the fan shroud/diffuser installed, it's a little tight but a short extension makes it work. I have had problems pulling the belt. It seems to go only so far and not enough, but just pull harder. It's not even so much that you notice it move any more, but it will, just enough to get the kickstand in place. You can feel the difference a little better when you pull again to let the kickstand drop away.
Old Nov 23, 2019 | 06:31 AM
SmackDaddy's Avatar
SmackDaddy
You can buy a slim tensioner wrench for about $15 or build one like the one in the 6.0 Tech Folder up top here. You guys are wearing me out with the screwdrivers...haha
Old Nov 23, 2019 | 07:16 AM
TooManyToys.'s Avatar
TooManyToys.
Ain't got no stator, got no problem.
Old Nov 23, 2019 | 07:34 AM
SmackDaddy's Avatar
SmackDaddy
I am contemplating putting my stator back in this time...that thing is a pain! Age old argument I know.
Old Nov 23, 2019 | 08:36 AM
TooManyToys.
I've had the same thoughts if I'm not changing out alternators to test things all the time.
Old Nov 25, 2019 | 06:37 AM
Fuzzpuss's Avatar
Fuzzpuss
I got rid of my stator this summer. It's never going back on.
Old Nov 25, 2019 | 06:53 AM
Fuzzpuss's Avatar
Fuzzpuss
I pulled it and had it stripped down to the block in 12 hours, I’m getting fast...haha
I have some interesting photos of the decks after 5200 miles. I might start a new thread.
I wish you would start a new thread. And please include all the images and info you've posted in several other threads as it's kind of all over the place right now. It would be nice to have it consolidated and would make a great reference.
Same goes for Jack's build. I'm specifically thinking about all the info in the "South Houston Engine Heads???" thread and these pics here. If it's all in your build thread already then nevermind, Jack. It's been a while since I've been there as I don't get email updates for some reason.
Old Nov 25, 2019 | 07:49 AM
  #28
TooManyToys.
I get it, I've thought of that issue too. The problem for me is I step away from this "project" for months at a time. And even with that my videos are way, way behind what I actually do, so they don't match up either. But if someone is doing something and I think something may be pertinent, I drop that something in. I think I'm just going to post the videos on YT and not here, I've got videos here slashed all over the place with little of a story, and most people want to follow a story in a shorter timeframe in a single thread. Some of these treads get discussions, and others get no response.
Old Nov 25, 2019 | 09:32 AM
  #29
IHateCommieCars
Ok, I'm an idiot. What are y'all calling the stator?
Old Nov 25, 2019 | 10:16 AM
  #30
Fuzzpuss's Avatar
Fuzzpuss
The stator is the inner fan shroud that bolts to the engine.
