Detroit 6.2 L v8 Diesel engine
Hi everyone
I have just purchased the Chevrolet 6.2 L Diesel engine and I want to fit it into my Ford F-250 custom of 1979; are these going to be compatible or modifications needed on engine mounts or bell house?? Any advice will be appreciated.
Do-able, yes, lots of work, yes. I'd imagine if you're going manual. you could build an NP435 with a Chevy input shaft and use a Chevy bellhousing, Ford from there back. Custom motor mounts, then hook everything else up. When you get done, though, you're going to have a fairly anemic time-bomb of an engine in a really solid pickup. For the work involved, a 4BT Cummins would make a LOT more sense to me......
The 6.2 diesel was pretty underpowered, like many engines of that era, but generally speaking they were reliable, good on fuel. Lots of farmers had them back in the day around this area (the chevy guys at least) and they all had good luck with them, with the rare exception. That being said they also had to be used like they were in a half ton, so light duty. I think most of the issues happened when guys actually tried to work them hard.
If I were to swap to a diesel, I would swap a cummins 6bt, and beef up the front suspension a little. You likely wouldnt even have to beef up the suspension as guys have hooked up plows and whatnot to the front of the f250s which would weigh more.
civicmindeddogooder
11-05-2010 07:03 PM
mike-db
04-28-2010 08:38 PM
2ndmouse
16
06-23-2004 02:36 PM
